Aller au contenu principal
Lenovo ThinkPad X140e Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X140e Hard Drive Replacement, Back Panel: étape 1, image 1 de 1
    • Flip the laptop upside down so that the battery is facing away from you.
    • Battery removal is not necessary to complete this guide.
  2. Lenovo ThinkPad X140e Hard Drive Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X140e Hard Drive Replacement: étape 2, image 2 de 2
    • Locate the three 3 mm Phillips #0 screws on the back panel.
    • Remove each screw using a small Phillips #0 screwdriver.
  3. Lenovo ThinkPad X140e Hard Drive Replacement: étape 3, image 1 de 1
    • Using a small plastic opening tool, pry off the back casing starting at a point closest to you and working around the perimeter of the case.
  4. Lenovo ThinkPad X140e Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • After removing the back panel, locate the hard drive located to the far left. It is distinguishable from other parts based on it's rectangular shape.
  5. Lenovo ThinkPad X140e Hard Drive Replacement: étape 5, image 1 de 2 Lenovo ThinkPad X140e Hard Drive Replacement: étape 5, image 2 de 2
    • Remove the four 3.5 mm Phillips #0 screws attached on the four corners of the hard drive.
  6. Lenovo ThinkPad X140e Hard Drive Replacement: étape 6, image 1 de 2 Lenovo ThinkPad X140e Hard Drive Replacement: étape 6, image 2 de 2
    • Slide the hard drive to the left.
    • Grip the hard drive on both sides and proceed to lift up to remove the hard drive.
kevin hull
Membre depuis le 10/05/16
213 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 20-5, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 membres
5 tutoriels rédigés
Un commentaire
How do you reformat the hard-drive? I understand physically replacing the equipment, but how do I reformat it with a windows operating system? My email is amwindham@aol.com.
amwindham - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 27
Total : 1,667
