Introduction
Having a problem with Hard Disk in your Lenovo X240 ? Follow along while we show you how to get it replaced! All you need is your iFixit Toolkit.
Flip the laptop upside down as shown in the photo.
  • Flip the laptop upside down as shown in the photo.
Ajouter un commentaire
Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop. Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
Remove the back cover using the opening tools.
  • Remove the back cover using the opening tools.
  • Gently use the plastic opening tools to prevent scratching your device.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the Hard Disk Drive card by  screwing the 2 0.2mm Phillips screw
  • Remove the Hard Disk Drive card by screwing the 2 0.2mm Phillips screw
Disconnect the cabel
  • Disconnect the cabel
Take off the connector by carefully popping its holders out of place
  • Take off the connector by carefully popping its holders out of place
Reconnect  the cable the new Hard Disk Drive
  • Reconnect the cable the new Hard Disk Drive
place the connector in order to hold the cable
  • place the connector in order to hold the cable
Place the new Hard Drive Disk
  • Place the new Hard Drive Disk
Mohammed Alsaadi
Membre depuis le 20/09/2017
201 Réputation
2 tutoriels rédigés
Équipe
Hello, i think you forgot to disconnect internal battery first before you replace something
shofaribagus - Réponse
Voir les statistiques:
Dernières 24 heures : 15
7 derniers jours : 56
30 derniers jours : 250
Total : 1,106
