Aller au contenu principal
Lenovo ThinkPad X260 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X260 Cooling Fan Replacement, External Battery: étape 1, image 1 de 2 Lenovo ThinkPad X260 Cooling Fan Replacement, External Battery: étape 1, image 2 de 2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Cooling Fan Replacement: étape 2, image 1 de 3 Lenovo ThinkPad X260 Cooling Fan Replacement: étape 2, image 2 de 3 Lenovo ThinkPad X260 Cooling Fan Replacement: étape 2, image 3 de 3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Cooling Fan Replacement, Back Cover: étape 3, image 1 de 3 Lenovo ThinkPad X260 Cooling Fan Replacement, Back Cover: étape 3, image 2 de 3 Lenovo ThinkPad X260 Cooling Fan Replacement, Back Cover: étape 3, image 3 de 3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Cooling Fan Replacement: étape 4, image 1 de 3 Lenovo ThinkPad X260 Cooling Fan Replacement: étape 4, image 2 de 3 Lenovo ThinkPad X260 Cooling Fan Replacement: étape 4, image 3 de 3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Cooling Fan Replacement, Cooling Fan: étape 5, image 1 de 2 Lenovo ThinkPad X260 Cooling Fan Replacement, Cooling Fan: étape 5, image 2 de 2
    • Remove the four 2.9 mm screws that hold the cooling fan in order of 4, 3, 2, 1 using a Phillips #1 screwdriver.
    • Gently lift the plastic retaining flap to disconnect the ribbon cable.
    • The plastic that holds the ribbon wire in place is a black lever on a tan block.
  6. Lenovo ThinkPad X260 Cooling Fan Replacement: étape 6, image 1 de 2 Lenovo ThinkPad X260 Cooling Fan Replacement: étape 6, image 2 de 2
    • Gently remove the wires which run along the fan.
    • Remove the old cooling fan.
  7. Lenovo ThinkPad X260 Cooling Fan Replacement: étape 7, image 1 de 2 Lenovo ThinkPad X260 Cooling Fan Replacement: étape 7, image 2 de 2
    • Clean the old thermal paste off of the CPU.
    • The CPU, when clean, should have a glossy black finish.
  8. Lenovo ThinkPad X260 Cooling Fan Replacement: étape 8, image 1 de 3 Lenovo ThinkPad X260 Cooling Fan Replacement: étape 8, image 2 de 3 Lenovo ThinkPad X260 Cooling Fan Replacement: étape 8, image 3 de 3
    • Apply new thermal paste to the CPU.
    • Place the new fan in position and secure by reatching the screws in the order of 1, 2, 3, 4.
Alexander Webb
Membre depuis le 12/06/21
193 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 1-3, Harley Summer 2023 Membre de l'équipe IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 63
Total : 424
