Aller au contenu principal
Lenovo ThinkPad X390 Fan Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X390 Fan Replacement, Back Cover: étape 1, image 1 de 1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Fan Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X390 Fan Replacement: étape 2, image 2 de 2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Fan Replacement, Fan: étape 3, image 1 de 1
    • Unplug the fan connector from the motherboard.
  4. Lenovo ThinkPad X390 Fan Replacement: étape 4, image 1 de 1
    • Using the Phillips #0 screwdriver, unscrew the four screws holding the heat sink to the motherboard.
  5. Lenovo ThinkPad X390 Fan Replacement: étape 5, image 1 de 1
    • Lift the fan up and out and remove it from the device.
Nick Couch
Membre depuis le 09/28/21
252 Réputation
1 tutoriel rédigé
Équipe
Clemson, Team 5-1, Hunter Fall 2021 Membre de l'équipe Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 33
Total : 846
