Aller au contenu principal
Lenovo ThinkPad X390 Yoga Display Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X390 Yoga Display Replacement, Back Case: étape 1, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Display Replacement: étape 2, image 1 de 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Display Replacement: étape 3, image 1 de 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Display Replacement, Display: étape 4, image 1 de 2 Lenovo ThinkPad X390 Yoga Display Replacement, Display: étape 4, image 2 de 2
    • Disconnect the display connectors with a spudger or opening tool.
  5. Lenovo ThinkPad X390 Yoga Display Replacement: étape 5, image 1 de 1
    • Loosen the two 5.5mm screws using the Phillips #1 screwdriver.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 78
Total : 738
