The first  step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
  • The first step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
  • You should then find the battery lock release located in the top left corner, as indicated in the image.
Ajouter un commentaire
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
The next step is to simply move the switch from the locked position to the unlocked position.
  • The next step is to simply move the switch from the locked position to the unlocked position.
Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
  • Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
  • Simply move the switch over from the locked position to the unlocked position and pull the battery from its holder. You can now insert the new battery.
Ryan McCarthy
Membre depuis le 15/03/2018
643 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G2, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G2, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G2
2 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 16
Total : 22
