Aller au contenu principal
Lenovo ThinkPad Yoga 14 20FY Fan Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Back Cover: étape 1, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the indicated nine M2 x 6 mm nylon-coated screws using a Phillips head screwdriver.
    • The screws do not come all the way out. Do not force them out.
  2. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: étape 2, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: étape 2, image 2 de 2
    • After removing all of the screws, gently lift up on all covers to remove the back plate and reveal the interior of the device.
  3. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Fan: étape 3, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Fan: étape 3, image 2 de 2
    • Remove all 7 screws.
    • One of the screws is behind a black piece of the plastic.
  4. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: étape 4, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: étape 4, image 2 de 2
    • Use the flat end of the spudger to push the connector out of its socket .
    • Do not use the wire to pull the connector out!
  5. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: étape 5, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: étape 5, image 2 de 2
    • There is a wire looped around the fan. Use the spudger to pull the wires out of the loop.
  6. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: étape 6, image 1 de 1
    • Gently peel back a piece of tape in the bottom left corner of the fan.
  7. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: étape 7, image 1 de 1
    • Gently lift out the fan.
jose aguirre
Membre depuis le 04/19/17
264 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S14-G2, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S14-G2, Banghart Spring 2017
CPSU-BANGHART-S17S14G2
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 12
Total : 1,436
