Aller au contenu principal
Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Back Cover: étape 1, image 1 de 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: étape 2, image 1 de 2 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: étape 3, image 1 de 2 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: étape 3, image 2 de 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: étape 4, image 1 de 2 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: étape 4, image 2 de 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Hard Drive: étape 5, image 1 de 3 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Hard Drive: étape 5, image 2 de 3 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Hard Drive: étape 5, image 3 de 3
    • Pull back the plastic heat shield over the hard drive without tearing or completely removing it.
  6. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: étape 6, image 1 de 1
    • Using a Phillips screwdriver, remove the PH1 Phillips fastener and set it aside.
  7. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: étape 7, image 1 de 1
    • Using your index finger and thumb, gently pull the hard drive from its connection and remove it from the laptop.
8 autres ont terminé cette réparation.
Daniel Fernandez
Membre depuis le 02/14/18
963 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G3, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S2G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 33
Total : 6,440
