Aller au contenu principal
Lenovo ThinkPad Yoga Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad Yoga Keyboard Replacement, Battery: étape 1, image 1 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: étape 1, image 2 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Keyboard Replacement: étape 2, image 1 de 3 Lenovo ThinkPad Yoga Keyboard Replacement: étape 2, image 2 de 3 Lenovo ThinkPad Yoga Keyboard Replacement: étape 2, image 3 de 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: étape 3, image 1 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: étape 3, image 2 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: étape 3, image 3 de 3
    • Disconnect connectors. Use fingers to pinch and pull the connector out.
  4. Lenovo ThinkPad Yoga Keyboard Replacement, Fan: étape 4, image 1 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: étape 4, image 2 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: étape 4, image 3 de 3
    • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
    • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
    • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
    • Remove the fan from the motherboard.
  5. Lenovo ThinkPad Yoga Keyboard Replacement, Keyboard: étape 5, image 1 de 1
    • Remove twelve screws from the midframe using a Phillips #1 screwdriver.
  6. Lenovo ThinkPad Yoga Keyboard Replacement: étape 6, image 1 de 1
    • Use a spudger to pry open the keyboard panel.
    • Continue to pry until the panel is loose enough to take off.
  7. Lenovo ThinkPad Yoga Keyboard Replacement: étape 7, image 1 de 1
    • Remove the keyboard from the laptop.
2 autres ont terminé cette réparation.
Felicia McCarey
Membre depuis le 10/28/21
299 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Membre de l'équipe UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 46
30 derniers jours : 257
Total : 6,951
