Aller au contenu principal
Lenovo ThinkPad Yoga RAM Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad Yoga RAM Replacement, Battery: étape 1, image 1 de 3 Lenovo ThinkPad Yoga RAM Replacement, Battery: étape 1, image 2 de 3 Lenovo ThinkPad Yoga RAM Replacement, Battery: étape 1, image 3 de 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga RAM Replacement: étape 2, image 1 de 3 Lenovo ThinkPad Yoga RAM Replacement: étape 2, image 2 de 3 Lenovo ThinkPad Yoga RAM Replacement: étape 2, image 3 de 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga RAM Replacement, RAM: étape 3, image 1 de 3 Lenovo ThinkPad Yoga RAM Replacement, RAM: étape 3, image 2 de 3 Lenovo ThinkPad Yoga RAM Replacement, RAM: étape 3, image 3 de 3
    • Remove nine screws from the motherboard with a Phillips #1 screwdriver.
    • Remove all ribbon cables attached to the motherboard.
    • Lift the motherboard out of the device.
  4. Lenovo ThinkPad Yoga RAM Replacement: étape 4, image 1 de 3 Lenovo ThinkPad Yoga RAM Replacement: étape 4, image 2 de 3 Lenovo ThinkPad Yoga RAM Replacement: étape 4, image 3 de 3
    • Desolder the RAM to replace it.
    • You may also opt to replace the entire motherboard if soldering is not an option.
Michael Nessralla
Membre depuis le 10/28/21
171 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Membre de l'équipe UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 31
30 derniers jours : 95
Total : 1,345
