Introduction
Follow this guide to replace the fan on your Lenovo ThinkPad E540 laptop.
Push the battery release switches away from each other. Push the battery release switches away from each other.
  • Push the battery release switches away from each other.
Ajouter un commentaire
Remove the battery.
  • Remove the battery.
Remove the three 1.2mm Phillips #00 screws from the bottom panel.
  • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a plastic opening tool to pry off the bottom panel.
  • Use a plastic opening tool to pry off the bottom panel.
Heatsink and fan are connected. You have to remove both at the same time.
  • Heatsink and fan are connected. You have to remove both at the same time.
  • The heatsink and fan are found on the right side.
Remove the two 1mm Phillips #0 screws from the fan.
  • Remove the two 1mm Phillips #0 screws from the fan.
  • Unscrew the four 2mm Phillips s#0 screws from the heatsink.
    • The screws on the heatsink will stay attached to it.
To remove the  heatsink and fan, pull the fan upwards and  towards the center.
  • To remove the heatsink and fan, pull the fan upwards and towards the center.
Timothy Sumner
Membre depuis le 14/02/2018
929 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S2-G5, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 23
Total : 73
