Aller au contenu principal
Lenovo Thinkpad E585 Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo Thinkpad E585 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Remove the marked Screws.
    • Pry the backside of and put it aside.
  2. Lenovo Thinkpad E585 Hard Drive Replacement: étape 2, image 1 de 2 Lenovo Thinkpad E585 Hard Drive Replacement: étape 2, image 2 de 2
    • Pull gently on the marked pull tab. If it doesn't come out, pull harder.
    • After you pulled the Hard Drive Dummy out, remove the Connector.
  3. Lenovo Thinkpad E585 Hard Drive Replacement: étape 3, image 1 de 2 Lenovo Thinkpad E585 Hard Drive Replacement: étape 3, image 2 de 2
    • After the second step, you should have the dummy with the mounting hardware removed from the laptop.
    • Gently pull on the side until it comes off.
  4. Lenovo Thinkpad E585 Hard Drive Replacement: étape 4, image 1 de 1
    • Put your hard drive in the middle of the mounting hardware and align the sides with the holes on the hard drive. Make sure the pull tab is on the upside.
    • Push on it.
  5. Lenovo Thinkpad E585 Hard Drive Replacement: étape 5, image 1 de 1
    • Connect the connector.
    • Push on the ribbon cable to glue it to the underside.
  6. Lenovo Thinkpad E585 Hard Drive Replacement: étape 6, image 1 de 1
    • Finally, align the hard drive and push on the marked end.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 24
Total : 1,005
