Aller au contenu principal
Lenovo Thinkpad T440S Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Thinkpad T440S Battery Replacement, Back Panel: étape 1, image 1 de 2 Lenovo Thinkpad T440S Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440S Battery Replacement: étape 2, image 1 de 1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440S Battery Replacement: étape 3, image 1 de 2 Lenovo Thinkpad T440S Battery Replacement: étape 3, image 2 de 2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440S Battery Replacement: étape 4, image 1 de 1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440S Battery Replacement, Battery: étape 5, image 1 de 2 Lenovo Thinkpad T440S Battery Replacement, Battery: étape 5, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the three screws holding in the battery.
  6. Lenovo Thinkpad T440S Battery Replacement: étape 6, image 1 de 1
    • Use the spudger to lift the battery out of it's compartment.
    • Although shown in this photo, please refrain from using the metal spudger on any lithium-ion batteries. The metal spudger can easily puncture the battery and cause further problems with the device.
  7. Lenovo Thinkpad T440S Battery Replacement: étape 7, image 1 de 2 Lenovo Thinkpad T440S Battery Replacement: étape 7, image 2 de 2
    • Unclip the battery from the device.
    • Remove the battery from the device.
3 autres ont terminé cette réparation.
Terelle Montalvo
Membre depuis le 10/22/18
1 438 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 Membre de l'équipe UMass Dartmouth, Team S1-G5, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G5
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 66
Total : 4,453
