Introduction
This guide will help you replace the RAM of your device.
Pièces
Aucune pièce nécessaire.
Flip the device so the back is facing you.
  • Flip the device so the back is facing you.
  • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
Ajouter un commentaire
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use the blue Opening Tool to pry-open the back cover.
  • Use the blue Opening Tool to pry-open the back cover.
  • Slide it around the perimeter of the PC freeing the back cover.
  • Remove the back cover from the device.
Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick. Remove the first stick and and do the same thing to the second RAM stick.
  • Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick.
  • Remove the first stick and and do the same thing to the second RAM stick.
Ean Hobbs
Membre depuis le 18/01/2018
219 Réputation
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 9
