Introduction
This guide will document the process of upgrading or replacing memory in a Lenovo X200 laptop or tablet.
1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
  • 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
Ajouter un commentaire
2. Remove the panel to access the memory modules.
  • 2. Remove the panel to access the memory modules.
Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
  • Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
  • Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
  • Insert the notched end of the DIMM into the socket.
  • Press the DIMM firmly, and pivot it until it snaps into the place.
  • Make sure that it is firmly fixed in the slot and does not move easily.
Pièces jointes
James Finch
Membre depuis le 14/10/2017
189 Réputation
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 33
