Ce dont vous avez besoin
There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
There will be 2 other Philips screws under the cover there should also be two arrows pointing at each screw that needs to be removed.
Pull up the battery slightly by the tab and pull back
Remove the connector from the motherboard and pull the battery up and away from the board
Congratulations! You hopefully have successfully completed this guide! To reassemble your device follow the steps backwards.
4 autres ont terminé cette réparation.
