Aller au contenu principal
Lenovo Yoga 2 11" Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: étape 1, image 1 de 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: étape 2, image 1 de 1
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: étape 3, image 1 de 1
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: étape 4, image 1 de 1
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: étape 5, image 1 de 2 Lenovo Yoga 2 11" Battery Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: étape 6, image 1 de 1
    • Once all of the wires are detached, carefully remove the battery and replace.
12 autres ont terminé cette réparation.
Abbey Hickmann
Membre depuis le 10/07/15
197 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-3, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 membres
5 tutoriels rédigés
4 commentaires
how do I remove unathorized battery error?
Manuel Durugas - Réponse
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - Réponse
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - Réponse
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 42
Total : 26,588
