Aller au contenu principal
Lenovo Yoga 2 13" Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 2 13" Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Battery Replacement: étape 2, image 1 de 1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Battery Replacement, Battery: étape 3, image 1 de 1
    • Locate the battery of the laptop.
  4. Lenovo Yoga 2 13" Battery Replacement: étape 4, image 1 de 1
    • To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
  5. Lenovo Yoga 2 13" Battery Replacement: étape 5, image 1 de 1
    • Disconnect the battery from the laptop by pulling the power connector towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Yoga 2 13" Battery Replacement: étape 6, image 1 de 1
    • Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
12 autres ont terminé cette réparation.
Nichelle
Membre depuis le 03/11/15
1 550 Réputation
5 tutoriels rédigés
Équipe
Marist, Team 1-2, Laflen Spring 2015 Membre de l'équipe Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 18
30 derniers jours : 64
Total : 31,645
