Aller au contenu principal
Lenovo Yoga 2 Pro Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 2 Pro Battery Replacement, Battery: étape 1, image 1 de 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Battery Replacement: étape 2, image 1 de 1
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Battery Replacement: étape 3, image 1 de 1
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Battery Replacement: étape 4, image 1 de 1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Battery Replacement: étape 5, image 1 de 2 Lenovo Yoga 2 Pro Battery Replacement: étape 5, image 2 de 2
    • Remove the battery from the computer.
34 autres ont terminé cette réparation.
Thomas Simko
Membre depuis le 10/01/15
2 511 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 12-14, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 membres
12 tutoriels rédigés
13 commentaires
The cover does not come off “gently”- there are snaps all the way around that must be popped.
Colin Leitner - Réponse
where do I buy a quality replacement battery?
I checked ebay and amazon, and there are a bunch of them. But I don’t know which one I should buy.
Thanks in advance.
Can Coin - Réponse
Did you find a suitable replacement? I’m curious too - looks like prices are $60 or twice that. Worth paying more than bargain basement prices?
drwelby -
You can get a Lenovo replacement battery from Amazon. About US 46. Did it, replaced, but now machine says no battery installed! Have searched far and wide on the web, but haven’t found an answer. Lots of complaints that Lenovo and new battery don’t mix well. Still searching. BTW I bought the replacement per my comments above. It’s an exact match and they put black tap over the Lenovo name.
msalvatini - Réponse
Might work with #00 Phillips driver (haven’t tried yet), but they sure look like mini Torx heads on mine (star shaped).
christian - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 37
30 derniers jours : 113
Total : 47,247
