Aller au contenu principal
Lenovo Yoga 3 Pro Display Assembly Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 3 Pro Display Assembly Replacement, Battery: étape 1, image 1 de 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 2, image 1 de 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 3, image 1 de 1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 4, image 1 de 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 6, image 1 de 1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro Display Assembly Replacement, Speakers: étape 7, image 1 de 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 8, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 8, image 2 de 2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 9, image 1 de 3 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 9, image 2 de 3 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 9, image 3 de 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 10, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 10, image 2 de 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 11, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 11, image 2 de 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
  12. Lenovo Yoga 3 Pro Display Assembly Replacement, USB Ports: étape 12, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement, USB Ports: étape 12, image 2 de 2
    • Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
    • Ribbon connectors can be fragile, so be gentle when disconnecting them.
  13. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 13, image 1 de 1
    • Remove the three indicated 3.5 mm screws using the Philips 00 screwdriver.
  14. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 14, image 1 de 1
    • Remove the USB assembly.
    • If this is the side that was not working, then follow the steps backwards from here to put it back together.
  15. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 15, image 1 de 1
    • On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
  16. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 16, image 1 de 1
    • Remove the two 2.5 mm screws using the Philips 00 screwdriver.
  17. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 17, image 1 de 1
    • Use the plastic opening tool to lift the metal cable holders.
    • Exercise caution. Cable holders will break if lifted too far.
  18. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 18, image 1 de 1
    • Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
  19. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 19, image 1 de 1
    • Remove the USB assembly using the plastic opening tool.
  20. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 20, image 1 de 1
    • Disconnect the WiFi card from the USB assembly.
    • Be careful with the connectors on the WiFi card as they are fragile.
  21. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 21, image 1 de 1
    • Pull the second USB hub off.
    • Be careful when pulling out the cable.
  22. Lenovo Yoga 3 Pro Display Assembly Replacement, Display Assembly: étape 22, image 1 de 1
    • Remove the four 2mm screws using the Philips 00 screwdriver.
    • Remove the 2.5mm screw using the Philips 00 screwdriver.
  23. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 23, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 23, image 2 de 2
    • Open the three ribbon connecting tabs.
  24. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 24, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 24, image 2 de 2
    • Lift the board with the plastic opening tool.
    • Be careful lifting the board.
    • Open the pin connector.
    • Do not lift the board completely so as not to pull the ribbon connector.
  25. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 25, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 25, image 2 de 2
    • Remove the ten 3.5mm screws using the Philips 00 screwdriver.
    • Lay the laptop as shown.
  26. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 26, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 26, image 2 de 2
    • Use a spudger to lift the screw cover.
    • Lift slowly and carefully. The cover is very fragile.
  27. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 27, image 1 de 1
    • Remove the eight 2mm screws using the Philips 00 screw driver.
  28. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 28, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 28, image 2 de 2
    • Use the plastic opening tool to lift the screen cover from the screen assembly.
    • Do not insert the plastic opener too far in.
    • Slowly go around the perimeter of the screen to loosen all fasteners.
  29. Lenovo Yoga 3 Pro Display Assembly Replacement: étape 29, image 1 de 2 Lenovo Yoga 3 Pro Display Assembly Replacement: étape 29, image 2 de 2
    • Unclip the display assembly by sliding the display down, towards the lower edge of the upper case component. The clips will disengage and you will be able to lift the assembly out easily.
    • Be careful pulling off the assembly as to not rip the ribbon connector shown.
11 autres ont terminé cette réparation.
Federico LopezCasildo Jr
Membre depuis le 10/08/15
1 340 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-17, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 membres
15 tutoriels rédigés
2 commentaires
Thank you. Very useful.
SHINE K. RAJU - Réponse
Great guide, but I think you missed the part of removing the fan
302302302v - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 39
Total : 22,433
