Aller au contenu principal
Lenovo Yoga 3 Pro USB Ports Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 3 Pro USB Ports Replacement, Battery: étape 1, image 1 de 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro USB Ports Replacement: étape 2, image 1 de 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro USB Ports Replacement: étape 3, image 1 de 1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro USB Ports Replacement: étape 4, image 1 de 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro USB Ports Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro USB Ports Replacement: étape 6, image 1 de 1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro USB Ports Replacement, Speakers: étape 7, image 1 de 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro USB Ports Replacement: étape 8, image 1 de 2 Lenovo Yoga 3 Pro USB Ports Replacement: étape 8, image 2 de 2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro USB Ports Replacement: étape 9, image 1 de 3 Lenovo Yoga 3 Pro USB Ports Replacement: étape 9, image 2 de 3 Lenovo Yoga 3 Pro USB Ports Replacement: étape 9, image 3 de 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro USB Ports Replacement: étape 10, image 1 de 2 Lenovo Yoga 3 Pro USB Ports Replacement: étape 10, image 2 de 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro USB Ports Replacement: étape 11, image 1 de 2 Lenovo Yoga 3 Pro USB Ports Replacement: étape 11, image 2 de 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
  12. Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: étape 12, image 1 de 2 Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: étape 12, image 2 de 2
    • Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
    • Ribbon connectors can be fragile, so be gentle when disconnecting them.
  13. Lenovo Yoga 3 Pro USB Ports Replacement: étape 13, image 1 de 1
    • Remove the three indicated 3.5 mm screws using the Philips 00 screwdriver.
  14. Lenovo Yoga 3 Pro USB Ports Replacement: étape 14, image 1 de 1
    • Remove the USB assembly.
    • If this is the side that was not working, then follow the steps backwards from here to put it back together.
  15. Lenovo Yoga 3 Pro USB Ports Replacement: étape 15, image 1 de 1
    • On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
  16. Lenovo Yoga 3 Pro USB Ports Replacement: étape 16, image 1 de 1
    • Remove the two 2.5 mm screws using the Philips 00 screwdriver.
  17. Lenovo Yoga 3 Pro USB Ports Replacement: étape 17, image 1 de 1
    • Use the plastic opening tool to lift the metal cable holders.
    • Exercise caution. Cable holders will break if lifted too far.
  18. Lenovo Yoga 3 Pro USB Ports Replacement: étape 18, image 1 de 1
    • Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
  19. Lenovo Yoga 3 Pro USB Ports Replacement: étape 19, image 1 de 1
    • Remove the USB assembly using the plastic opening tool.
  20. Lenovo Yoga 3 Pro USB Ports Replacement: étape 20, image 1 de 1
    • Disconnect the WiFi card from the USB assembly.
    • Be careful with the connectors on the WiFi card as they are fragile.
  21. Lenovo Yoga 3 Pro USB Ports Replacement: étape 21, image 1 de 1
    • Pull the second USB hub off.
    • Be careful when pulling out the cable.
10 autres ont terminé cette réparation.
Caroline Seifert
Membre depuis le 10/01/15
538 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 12-17, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 membres
15 tutoriels rédigés
4 commentaires
Repaired customers Yoga 3 that had NO working USB ports whatsoever in less than an hour - after cleaning & replacing (no parts needed)
All USB ports were fully functional once again...
Great job & thank you for the help :)
admin - Réponse
This guide helped me quite a bit today. I really appreciate you providing it.
Jon Tucich - Réponse
Can you please help with information on where to get the DC input USB port part. My USB port is broken and unable to find it
Dheeraj - Réponse
None of the 3 USB ports were powering on.
Windows seemed happy and no drivers and bios update helped …
I took apart following this guide, cleaned all ports and PCBs with IPA and a toothbrush and now it’s all working again!
Thank you
ori elyada - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 53
Total : 13,271
