Introduction
Solid state drives are known to fail occasionally, but this doesn't mean you have to do away with your laptop entirely. Replacing a bad drive is as simple as removing the battery and a single screw. Failure can be caused by heat, voltage fluctuation, and age.
Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
  • Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
Ajouter un commentaire
Slide opening tool between the base and back cover.
  • Slide opening tool between the base and back cover.
Lift back cover.
  • Lift back cover.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the four 3.5 mm screws around the battery using the Phillips 00 screwdriver.
  • Remove the four 3.5 mm screws around the battery using the Phillips 00 screwdriver.
Disconnect the battery from the motherboard.
  • Disconnect the battery from the motherboard.
Gently lift and remove the battery.
  • Gently lift and remove the battery.
Remove the one JIS 1 screw holding the solid state drive in place.
  • Remove the one JIS 1 screw holding the solid state drive in place.
Gently pull the solid state drive out and up to remove it from the connector.
  • Gently pull the solid state drive out and up to remove it from the connector.
Andrew Keenan
Membre depuis le 30/11/2017
101 Réputation
1 tutoriel rédigé
Équipe
University of Maine, Team S1-G5, Diaz Fall 2017 Membre de l'équipe University of Maine, Team S1-G5, Diaz Fall 2017
UMAINE-DIAZ-F17S1G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 58
Total : 279
