Aller au contenu principal
Lenovo Yoga 720 Bottom Cover Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 720 Bottom Cover Replacement, Bottom Cover: étape 1, image 1 de 3 Lenovo Yoga 720 Bottom Cover Replacement, Bottom Cover: étape 1, image 2 de 3 Lenovo Yoga 720 Bottom Cover Replacement, Bottom Cover: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    T5 Torx Screwdriver
    $5.49
    J'achète
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720 Bottom Cover Replacement: étape 2, image 1 de 3 Lenovo Yoga 720 Bottom Cover Replacement: étape 2, image 2 de 3 Lenovo Yoga 720 Bottom Cover Replacement: étape 2, image 3 de 3
    iFixit Opening Tool
    $1.99
    J'achète
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720 Bottom Cover Replacement: étape 3, image 1 de 3 Lenovo Yoga 720 Bottom Cover Replacement: étape 3, image 2 de 3 Lenovo Yoga 720 Bottom Cover Replacement: étape 3, image 3 de 3
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
5 autres ont terminé cette réparation.
Aiden
Membre depuis le 09/19/15
17 429 Réputation
21 tutoriels rédigés
Un commentaire
Can’t seem to find information about this but why should I discharge the laptop to 25% before I do this?
I bought a new wifi card that I will put in.
Björn Ridell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 7,339
