Aller au contenu principal
Lenovo Yoga 720-15IKB Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: étape 1, image 1 de 3 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: étape 1, image 2 de 3 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: étape 1, image 3 de 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Battery Replacement: étape 2, image 1 de 2 Lenovo Yoga 720-15IKB Battery Replacement: étape 2, image 2 de 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Battery Replacement, Battery: étape 3, image 1 de 2 Lenovo Yoga 720-15IKB Battery Replacement, Battery: étape 3, image 2 de 2
    • Remove the four 4mm screws surrounding the battery with a Phillips #0 screwdriver.
    • Each is marked by "M2x5" with a small white arrow pointing to the screw itself.
  4. Lenovo Yoga 720-15IKB Battery Replacement: étape 4, image 1 de 2 Lenovo Yoga 720-15IKB Battery Replacement: étape 4, image 2 de 2
    • Pull firmly on the battery connector to disconnect it.
  5. Lenovo Yoga 720-15IKB Battery Replacement: étape 5, image 1 de 1
    • Lift the battery out of the case to remove it.
10 autres ont terminé cette réparation.
Matthew Bornhorst
Membre depuis le 01/23/20
495 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S19-G3, White Winter 2020 Membre de l'équipe Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 membres
25 tutoriels rédigés
3 commentaires
Excellent guide. Made the job a snap. Especially identifying the screwdriver bit requird.
James Smith - Réponse
Good guide. Fairly easy project. Getting the battery connector back in on the replacement battery was by far the hardest part. Be patient with it. It took me a few tries, but it slid in fairly easily once it was all lined up correctly.
Mark Haakenson - Réponse
Thank you for the great informative guide! ordering my battery and tools now!
justmelendez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 79
30 derniers jours : 277
Total : 11,231
