Introduction
The motherboard contains all the main components. In order to physically inspect and verify operation of components the motherboard should be removed or replaced if necessary.
Pièces
Aucune pièce nécessaire.
Be sure the ethernet and power cables are disconnected from the device.
  • Be sure the ethernet and power cables are disconnected from the device.
  • You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
Ajouter un commentaire
To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers. Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot.  Once you are hooked behind the boot, pull outwards. This will reveal two small Phillips-head screws.  Remove them.
  • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
  • Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot. Once you are hooked behind the boot, pull outwards.
  • This will reveal two small Phillips-head screws. Remove them.
  • Keep these two screws together.
Using two hands (one on the front of the device and the other on the back) apply pressure to the top and bottom seal while pulling the front and back away from each other. This requires significant amount of force.
  • Using two hands (one on the front of the device and the other on the back) apply pressure to the top and bottom seal while pulling the front and back away from each other.
    • This requires significant amount of force.
    • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
  • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
  • When removing the base, do not damage the wires that are attached to the device.
This is what the device looks like when it is fully opened.
  • This is what the device looks like when it is fully opened.
At this point, you may want to remove the antenna leads as well. Once the antennas have been removed, proceed to remove the remaining three phillips screws fastening the motherboard to the case.
  • At this point, you may want to remove the antenna leads as well.
  • Once the antennas have been removed, proceed to remove the remaining three phillips screws fastening the motherboard to the case.
  • Once the screws are removed, your motherboard will separate from the housing.
  • Keep these three screws together and separate from the outer case screws.
Javier
Membre depuis le 12/10/2011
40 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-17, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 3-17, Regan Fall 2011
CPSU-REGAN-F11S3G17
5 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 915
