Introduction
In this guide we will go over removing the top casing.
Pièces
Aucune pièce nécessaire.
Power down and unplug the device.
  • Power down and unplug the device.
Ajouter un commentaire
Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of      Installing the Antennas Guide: Linksys WAP54g Antennas Replacement
Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
  • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
  • This may require a bit of force.
Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts. Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes. Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
  • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
  • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
  • Once the top panel is removed the main board will still be attached to the bottom panel.
From here you can take apart the rest of the router apart by following subsequent guides.
Derek Myers
Membre depuis le 04/10/2011
243 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 21-21, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,238
