Introduction
Is your disco ball not giving off the right groovy colors that it once did? This guide will teach you how to replace the colored panels so you can get back to partying!
Pièces
Aucune pièce nécessaire.
Unplug the device to avoid injury.
  • Unplug the device to avoid injury.
  • Turn the device over, so that the base is on top.
Ajouter un commentaire
Compress the tab by pushing towards the center of the device with a spudger. While compressing the tab, peel the base away from the rotating head. While compressing the tab, peel the base away from the rotating head.
  • Compress the tab by pushing towards the center of the device with a spudger.
  • While compressing the tab, peel the base away from the rotating head.
If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches. Insert a new color panel by pushing it into place while lining up the tabs with the notches. Insert a new color panel by pushing it into place while lining up the tabs with the notches.
  • Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches.
  • Insert a new color panel by pushing it into place while lining up the tabs with the notches.
Nick Kaprielian
Membre depuis le 14/01/2014
495 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 17-3, Forte Winter 2014 Membre de l'équipe Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 357
