Introduction
If your buttons are sticking and they cannot be cleaned from the outside, here is how you can clean it from the inside.
Pièces
Aucune pièce nécessaire.
To get into the controller, you will need to unscrew the 7 screws on the back.
  • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in red.
Ajouter un commentaire
With the screws removed, turn the controller upside down and separate the front end from the back end. It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go. There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  • With the screws removed, turn the controller upside down and separate the front end from the back end.
  • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
Turn over the front side of the controller to remove all the buttons.
  • Turn over the front side of the controller to remove all the buttons.
  • Wipe each individual button down with a piece of cloth and rubbing alcohol.
Ligne d'arrivée
4 autre(s) ont terminé cette réparation.
Brian Neuman
Membre depuis le 20/01/2015
512 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 7-4, Remmell Winter 2015 Membre de l'équipe USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 membres
3 tutoriels rédigés
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Réponse
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 17
30 derniers jours : 82
Total : 1,927
