Introduction
After removing the top cover you will be able to replace the mouse buttons.
Pièces
Aucune pièce nécessaire.
Hold the mouse in your hand so that the bottom side is facing upward.
  • Hold the mouse in your hand so that the bottom side is facing upward.
  • Locate the #1 screw towards the bottom half of the mouse.
  • Take the 4.76 mm Phillips screwdriver and unscrew the #1 screw that was previously located.
باز کردن پیچ زیر موس
h sh - Réponse
Place the mouse back on the hard surface, with the bottom side touching the hard surface. Gently, lift up the top cover of the mouse and remove.
  • Place the mouse back on the hard surface, with the bottom side touching the hard surface.
  • Gently, lift up the top cover of the mouse and remove.
جدا کردن قاب رو و زیر موس
h sh - Réponse
Locate the two tabs that are protruding from the button assembly. Be careful not to break either of the two tabs by squeezing too hard.
  • Locate the two tabs that are protruding from the button assembly.
  • Be careful not to break either of the two tabs by squeezing too hard.
  • Now pinch the tabs together to free the buttons.
Ajouter un commentaire
Free the button assembly from the top cover by bringing the button section down. Then sliding the button assembly out from the top cover through the opening.
  • Free the button assembly from the top cover by bringing the button section down.
  • Then sliding the button assembly out from the top cover through the opening.
  • When fully parted the top cover and the button assembly should look like this.
Maximilian Betkowski
Membre depuis le 11/01/2013
157 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 5-14, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 18
Total : 1,380
