Aller au contenu principal
Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement
Ce dont vous avez besoin
  1. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement, Capacitors: étape 1, image 1 de 3 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement, Capacitors: étape 1, image 2 de 3 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement, Capacitors: étape 1, image 3 de 3
    • Obtain (4) 1000uF capacitors rated for 25 volts. The replacement capacitors featured in this guide were purchased from Digi-key. Digi-key part number: UHE1E102MHD6. http://search.digikey.com/scripts/DkSear...
    • Additional suggested tools for this repair are pictured.
  2. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 2, image 1 de 1
    • Caution: Be mindful of the dangerous high voltage that exist in this device when powered and for a short time afterward.
    • Place the camera upside down.
    • Using a small flat tool, pry off the plastic covers on each side of the case (outlined in orange)
  3. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 3, image 1 de 1
    • Removal of the covers reveal six philips head screws (green highlight).
    • Unscrew all six screws.
  4. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 4, image 1 de 2 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 4, image 2 de 2
    • Flip the camera so the top is right-side up.
    • Remove the top of the case.
    • Notice the four damaged capacitors C26, C27, C31 and C32 (red highlight).
  5. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 5, image 1 de 1
    • Unscrew all four phillips head screws in each corner (green highlight).
    • Disconnect power cable (yellow highlight).
    • Lift and remove the clear front plastic lens cover.
    • Lift the circuit board and camera assebly out of the case.
    • Carefully separate the LED assembly from the four small connectors (highlighted in blue). Note: This step is not required for this repair. However, it reduces the possibility of inadvertent damage during the process.
  6. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 6, image 1 de 3 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 6, image 2 de 3 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 6, image 3 de 3
    • Desolder and remove the four capacitors (red highlight).
    • Suggestion: Mark the capacitors on top and on the bottom of the board to avoid damaging another component.
  7. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 7, image 1 de 1
    • Clean and remove remaining solder or debris from the area.
    • Cut leads on new capacitors to fit.
    • Solder the four new capacitors in place.
    • Notice: Pay attention to the polarity of the capacitors.
    • Insulate the leads and gently bend the capacitors to fit.
  8. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: étape 8, image 1 de 1
    • Suggestion: Before full reassembly, reattach the LED module, place the board and camera module into the case and reconnect the A/C cable to ensure proper operation.
6 autres ont terminé cette réparation.
Un commentaire
I did the repair worked for 5 min's then starts acting up. Before the fix wouldn't work at all. Is there anymore suggestions?
martin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 48
Total : 9,563
