Aller au contenu principal
Lorex LW2744 Wi-Fi Antenna Replacement
Ce dont vous avez besoin
  1. Lorex LW2744 Wi-Fi Antenna Replacement, Battery: étape 1, image 1 de 1
    • Remove the 5.0mm screw using the Phillips #0 head screwdriver.
  2. Lorex LW2744 Wi-Fi Antenna Replacement: étape 2, image 1 de 1
    • Insert metal spudger as shown in the picture. Move spudger along to the other side until both snaps come loose.
  3. Lorex LW2744 Wi-Fi Antenna Replacement: étape 3, image 1 de 1
    • Picture shows the removed battery cover.
  4. Lorex LW2744 Wi-Fi Antenna Replacement: étape 4, image 1 de 1
    • Slide the battery out by pulling on one of two plastics tabs.
  5. Lorex LW2744 Wi-Fi Antenna Replacement, Wi-Fi Antenna: étape 5, image 1 de 1
    • Remove the remaining five 6.0 mm Phillips #0 screws.
  6. Lorex LW2744 Wi-Fi Antenna Replacement: étape 6, image 1 de 1
    • Use the spudger to remove the back cover. Insert the spudger between the back and front cover. Once inserted, you will need to move it around the perimeter to release the snaps holding it together.
  7. Lorex LW2744 Wi-Fi Antenna Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Once back cover is removed, the speaker wire will need to be removed. Use tweezers to remove wire.
  8. Lorex LW2744 Wi-Fi Antenna Replacement: étape 8, image 1 de 1
    • Begin by heating the exposed end of the grey lead with the tip of a soldering iron while simultaneously pulling the lead away from the connection, using tweezers to grasp the lead by the insulation.
    • For more information on soldering, check out this repair guide: iFixit Soldering
Yancey Crase
Membre depuis le 03/26/18
217 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Harley Spring 2018 Membre de l'équipe IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 265
