Aller au contenu principal
MSI GE62 Apache Pro 004 Motherboard Replacement
Ce dont vous avez besoin
  1. MSI GE62 Apache Pro 004 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Motherboard Replacement: étape 2, image 1 de 2 MSI GE62 Apache Pro 004 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Motherboard Replacement: étape 3, image 1 de 3 MSI GE62 Apache Pro 004 Motherboard Replacement: étape 3, image 2 de 3 MSI GE62 Apache Pro 004 Motherboard Replacement: étape 3, image 3 de 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: étape 4, image 1 de 2 MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: étape 4, image 2 de 2
    • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
  5. MSI GE62 Apache Pro 004 Motherboard Replacement: étape 5, image 1 de 3 MSI GE62 Apache Pro 004 Motherboard Replacement: étape 5, image 2 de 3 MSI GE62 Apache Pro 004 Motherboard Replacement: étape 5, image 3 de 3
    • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
    • Unfasten the 8 screws holding the motherboard in place.
    • Pull out the motherboard.
Alexander
Membre depuis le 02/19/18
86 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S15-G5, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 membres
5 tutoriels rédigés
Un commentaire
Hi,can i change msi ge62 6qf motherboard with ge62 7rd apache pro?
Its essential for me.tnx.
rahim dargahi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 10
Total : 1,963
