Aller au contenu principal
Mac mini Late 2014 Antenna Plate Replacement
Ce dont vous avez besoin
  1. Mac mini Late 2014 Antenna Plate Replacement, Bottom Cover: étape 1, image 1 de 1
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 Antenna Plate Replacement: étape 2, image 1 de 3 Mac mini Late 2014 Antenna Plate Replacement: étape 2, image 2 de 3 Mac mini Late 2014 Antenna Plate Replacement: étape 2, image 3 de 3
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 Antenna Plate Replacement: étape 3, image 1 de 2 Mac mini Late 2014 Antenna Plate Replacement: étape 3, image 2 de 2
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 Antenna Plate Replacement, Antenna Plate: étape 4, image 1 de 1
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 Antenna Plate Replacement: étape 5, image 1 de 2 Mac mini Late 2014 Antenna Plate Replacement: étape 5, image 2 de 2
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 Antenna Plate Replacement: étape 6, image 1 de 1
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 Antenna Plate Replacement: étape 7, image 1 de 2 Mac mini Late 2014 Antenna Plate Replacement: étape 7, image 2 de 2
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 Antenna Plate Replacement: étape 8, image 1 de 2 Mac mini Late 2014 Antenna Plate Replacement: étape 8, image 2 de 2
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 Antenna Plate Replacement: étape 9, image 1 de 1
    • Remove the antenna plate from the Mac mini.
10 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
465 777 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
Un commentaire
Hello
I had really a problem with this instructions! The T6H Screw-Driver in the fixit-kit doesn’t fit in the holes of the 6 screws who hold the cover? Has Apple changes the screws of the macmini 2014, or has the T6H Screw-Driver has to much tolerance while produced!
I need to replace the HDD of the fusion drive! I will need to buy, HighEnd Tools to open my Cover ?!?
Gerard Dirks - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 80
Total : 13,072
