Aller au contenu principal
MacBook Air 11" Early 2014 I/O Board Replacement
Ce dont vous avez besoin
  1. MacBook Air 11" Early 2014 I/O Board Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    J'achète
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2014 I/O Board Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2014 I/O Board Replacement, Battery Connector: étape 3, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement, Battery Connector: étape 3, image 2 de 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board Cable: étape 4, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board Cable: étape 4, image 2 de 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2014 I/O Board Replacement: étape 5, image 1 de 1
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Early 2014 I/O Board Replacement, Fan: étape 6, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement, Fan: étape 6, image 2 de 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Early 2014 I/O Board Replacement: étape 7, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: étape 7, image 2 de 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Early 2014 I/O Board Replacement: étape 8, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: étape 8, image 2 de 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Early 2014 I/O Board Replacement: étape 9, image 1 de 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Early 2014 I/O Board Replacement: étape 10, image 1 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: étape 10, image 2 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: étape 10, image 3 de 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. MacBook Air 11" Early 2014 I/O Board Replacement, Battery: étape 11, image 1 de 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  12. MacBook Air 11" Early 2014 I/O Board Replacement: étape 12, image 1 de 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  13. MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board: étape 13, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board: étape 13, image 2 de 2
    • Disconnect the I/O board power cable from the logic board by pulling the cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  14. MacBook Air 11" Early 2014 I/O Board Replacement: étape 14, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: étape 14, image 2 de 2
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  15. MacBook Air 11" Early 2014 I/O Board Replacement: étape 15, image 1 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: étape 15, image 2 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: étape 15, image 3 de 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  16. MacBook Air 11" Early 2014 I/O Board Replacement: étape 16, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: étape 16, image 2 de 2
    • Use the tip of a spudger to pry under the speaker cable near the connector to lift the connector straight up out of its socket.
  17. MacBook Air 11" Early 2014 I/O Board Replacement: étape 17, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: étape 17, image 2 de 2
    • De-route the cable from its notch in the I/O board.
  18. MacBook Air 11" Early 2014 I/O Board Replacement: étape 18, image 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: étape 18, image 2 de 2
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  19. MacBook Air 11" Early 2014 I/O Board Replacement: étape 19, image 1 de 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    • In some models this is a 3.1 mm T5 Torx screw.
  20. MacBook Air 11" Early 2014 I/O Board Replacement: étape 20, image 1 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: étape 20, image 2 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: étape 20, image 3 de 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
11 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
465 762 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
Un commentaire
Does the IO board on this model contain the hall effect sensor(lid sensor)? Where is it located and what does it look like?
Marik - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 19
Total : 6,791
