Aller au contenu principal
MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement
Ce dont vous avez besoin
  1. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    J'achète
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, Battery: étape 3, image 1 de 2 MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, Battery: étape 3, image 2 de 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Card: étape 4, image 1 de 2 MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Card: étape 4, image 2 de 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement: étape 5, image 1 de 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement: étape 6, image 1 de 1
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth board from the Air.
12 autres ont terminé cette réparation.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
502 746 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 731 tutoriels rédigés
Un commentaire
Is that a mini pcie cable that is used for the networking card? I just am wondering if it is possible to disconnect the airport card and install a egpu there
Todd - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 20
Total : 8,633
