Aller au contenu principal
MacBook Air 11" Mid 2012 I/O Board Cable Replacement
Ce dont vous avez besoin
  1. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    J'achète
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: étape 3, image 1 de 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: étape 3, image 2 de 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: étape 4, image 1 de 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: étape 4, image 2 de 2
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: étape 5, image 1 de 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement: étape 5, image 2 de 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
3 autres ont terminé cette réparation.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
502 993 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 180 tutoriels rédigés
Un commentaire
You only show the basic part of the removal. You do not show how to actually remove that board. You should have shown more steps.
Steven Pierce - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 19
Total : 2,845
