Introduction
The MacBook Air hinges house the Webcam, Wifi/Bluetooth Antennae and the Display Connectors within them. This guide will show you how to remove the bezel and replace the hinges and also replace these connectors.
Ce dont vous avez besoin
Slide the plastic chin to the right and off the display.
Remove the two PH000 screws holding in the LCD board in
To replace the display connection you can open the retaining latch and disconnect the cable.
To reassemble your device, follow these instructions in reverse order. I recommend cleaning it with alcohol and using VHB tape for glueing the bezel back on.
2 autres ont terminé cette réparation.
Un commentaire
Buen paso a paso, pero es de tener en cuenta 2 consideraciones. 1. al momento de la apertura, ¿donde se consigue una cama calefactora tran grande?. 2. al momento del sellado, ¿se debe usar un adesivo especial?
