Introduction
Use this guide to replace the AirPort/Bluetooth card.
  • Before proceeding, power down your machine. Close the display and lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 9 mm P5 Pentalobe screws
    • Eight 2.6 mm P5 Pentalobe screws
  • The special screwdriver needed to remove the ten 5-point Pentalobe screws can be found here.
These pentalobe screw sizes can't possibly be right - not even close. Should they perhaps be 0,8 mm and 1,2 mm?
Rulle Boer - Réponse
The screw sizes refer to the length of the shaft, not the diameter of the head or socket. P5 is the standard pentalobe size for all these screws, regardless of length.
I agree that the notation is a little confusing. I think it's because, with standard sized hardware like for your house, you have shaft diameter (say 1/8" or 3mm) and shaft length (say 3" or 7.5cm). So we're programmed to think of small numbers like that as diameter. But in this case, they're length.
budpegasus - Réponse
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Réponse
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Réponse
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Réponse
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Réponse
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Réponse
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Réponse
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Réponse
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Réponse
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
Jeannie Crowley - Réponse
When closing this back up make sure that the antenna cable is tucked away neatly
Gabriel - Réponse
To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery. Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
  • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
  • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
  • Do not lift upward on the connector as you disconnect it.
Ajouter un commentaire
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board. To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
  • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
  • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
  • Remove the AirPort/Bluetooth card from the Air.
15 autre(s) ont terminé cette réparation.
Jeff Suovanen
Membre depuis le 06/08/2013
156 895 Réputation
393 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
115 membres
5 778 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 22
30 derniers jours : 124
Total : 10,095
