Aller au contenu principal
MacBook Air 13" Early 2015 Right Speaker Replacement
Ce dont vous avez besoin
  1. MacBook Air 13" Early 2015 Right Speaker Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    J'achète
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2015 Right Speaker Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2015 Right Speaker Replacement, Battery Connector: étape 3, image 1 de 2 MacBook Air 13" Early 2015 Right Speaker Replacement, Battery Connector: étape 3, image 2 de 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2015 Right Speaker Replacement, Battery: étape 4, image 1 de 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.9 mm T5 Torx screws
    • Two 3.0 mm T5 Torx screws
  5. MacBook Air 13" Early 2015 Right Speaker Replacement: étape 5, image 1 de 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • Your replacement battery may arrive with a plastic film lightly adhered to the top surface. Remove this film when you install the battery. However, if the film is glued on and is difficult to remove, you should leave the film in place.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air 13" Early 2015 Right Speaker Replacement, Right Speaker: étape 6, image 1 de 1
    • Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
    • Pry up from beneath the wires.
  7. MacBook Air 13" Early 2015 Right Speaker Replacement: étape 7, image 1 de 3 MacBook Air 13" Early 2015 Right Speaker Replacement: étape 7, image 2 de 3 MacBook Air 13" Early 2015 Right Speaker Replacement: étape 7, image 3 de 3
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Remove the right speaker from the upper case.
7 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
465 602 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 722 tutoriels rédigés
Un commentaire
Anleitung ist perfekt. Läuft einwandfrei.
Lediglich beim Lösen des angeklebten Lautsprechers muss man etwas aufpassen. Sonst erste Sahne!
BenZ78 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 43
Total : 8,211
