Aller au contenu principal
MacBook Air 13" Mid 2012 Upper Case Replacement
Ce dont vous avez besoin
  1. MacBook Air 13" Mid 2012 Upper Case Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    J'achète
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2012 Upper Case Replacement, Battery Connector: étape 3, image 1 de 2 MacBook Air 13" Mid 2012 Upper Case Replacement, Battery Connector: étape 3, image 2 de 2
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
  4. MacBook Air 13" Mid 2012 Upper Case Replacement, I/O Board Cable: étape 4, image 1 de 1
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 5, image 1 de 1
    • Carefully peel the I/O board cable from the top of the fan.
  6. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 6, image 1 de 2 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 6, image 2 de 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  7. MacBook Air 13" Mid 2012 Upper Case Replacement, Fan: étape 7, image 1 de 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  8. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 8, image 1 de 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
  9. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 9, image 1 de 1
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
  10. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 10, image 1 de 1
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
  11. MacBook Air 13" Mid 2012 Upper Case Replacement, I/O Board: étape 11, image 1 de 1
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
  12. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 12, image 1 de 1
    • Pull the camera cable parallel to the face of the I/O board toward the hinge of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
    • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
  13. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 13, image 1 de 1
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  14. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 14, image 1 de 2 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 14, image 2 de 2
    • Use the tip of a spudger to flip up the retaining flap securing the microphone ribbon cable to the I/O board.
    • Use the tip of a spudger to remove the volume button ribbon cable from its ZIF connector on the I/O board.
  15. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 15, image 1 de 1
    • Remove the single 4.0 mm T5 Torx screw securing the I/O board to the upper case.
  16. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 16, image 1 de 1
    • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
  17. MacBook Air 13" Mid 2012 Upper Case Replacement, Battery: étape 17, image 1 de 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  18. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 18, image 1 de 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  19. MacBook Air 13" Mid 2012 Upper Case Replacement, Logic Board: étape 19, image 1 de 2 MacBook Air 13" Mid 2012 Upper Case Replacement, Logic Board: étape 19, image 2 de 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  20. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 20, image 1 de 2 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 20, image 2 de 2
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Use your spudger to help pull the cable out of its socket.
  21. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 21, image 1 de 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry up from beneath the cables.
  22. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 22, image 1 de 3 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 22, image 2 de 3 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 22, image 3 de 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  23. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 23, image 1 de 2 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 23, image 2 de 2
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
  24. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 24, image 1 de 1
    • Gently de-route the antenna cables from the slot cut into the logic board.
  25. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 25, image 1 de 1
    • Remove the single 2.85 mm T5 Torx screw securing the SSD to the logic board.
  26. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 26, image 1 de 2 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 26, image 2 de 2
    • To avoid damaging its socket, do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  27. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 27, image 1 de 1
    • Remove the six 6.3 mm T5 Torx screws securing the logic board to the upper case.
  28. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 28, image 1 de 1
    • Remove the inner two 4.9 mm T8 Torx screws securing the antenna cable retainer and left clutch hinge to the upper case.
  29. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 29, image 1 de 1
    • Push the antenna cable retainer away slightly and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
  30. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 30, image 1 de 1
    • Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
    • Hold the antenna cables out of the way as you lift the heat sink end of the logic board out of the upper case.
  31. MacBook Air 13" Mid 2012 Upper Case Replacement, Display Assembly: étape 31, image 1 de 1
    • Gently de-route the antenna cables out of the channel cut into the upper case.
  32. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 32, image 1 de 1
    • Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
    • We intentionally have you leave the third screw in to aid in future steps.
  33. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 33, image 1 de 1
    • Open the display until it is perpendicular to the upper case and place it on a table as shown.
    • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
  34. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 34, image 1 de 1
    • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
    • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
  35. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 35, image 1 de 1
    • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
  36. MacBook Air 13" Mid 2012 Upper Case Replacement, Upper Case: étape 36, image 1 de 3 MacBook Air 13" Mid 2012 Upper Case Replacement, Upper Case: étape 36, image 2 de 3 MacBook Air 13" Mid 2012 Upper Case Replacement, Upper Case: étape 36, image 3 de 3
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Remove the right speaker from the upper case.
  37. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 37, image 1 de 3 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 37, image 2 de 3 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 37, image 3 de 3
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
  38. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 38, image 1 de 2 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 38, image 2 de 2
    • Use the tip of a spudger to pry the microphone away from the left side of the upper case.
    • Remove the microphone from the upper case.
    • Upper case remains.
  39. MacBook Air 13" Mid 2012 Upper Case Replacement, Upper Case: étape 39, image 1 de 2 MacBook Air 13" Mid 2012 Upper Case Replacement, Upper Case: étape 39, image 2 de 2
    • Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
  40. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 40, image 1 de 3 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 40, image 2 de 3 MacBook Air 13" Mid 2012 Upper Case Replacement: étape 40, image 3 de 3
    • While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
  41. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 41, image 1 de 1
    • Remove the following seven screws:
    • Six 1.6 mm Phillips screws securing the trackpad to the upper case.
    • One 1.4 mm T5 Torx set screw from its tapped hole near the front edge of the upper case.
    • During reassembly, do not over-tighten the set screw, as the button will cease to click at a certain point. Adjust the set screw until the movable side of the trackpad has minimal play.
  42. MacBook Air 13" Mid 2012 Upper Case Replacement: étape 42, image 1 de 1
    • Carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
    • Remove the trackpad from the upper case.
    • The upper case remains.
62 autres ont terminé cette réparation.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
503 085 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 299 tutoriels rédigés
9 commentaires
On step 41 the 1.4 mm T5 Torx set screw remember that this screw does not come out. I was racking my brain for like 30 minutes and realized that this screw is not and can not be removed, rather it's just used to adjust the sensitivity of the clicking on the mouse pad.
dtlam76 - Réponse
I got mine out, but it was unnecessary for the procedure. You're right that it doesn't hold anything down really.
lionfish -
I had a Torx 6 in order to not strip the screw...
jan szubert -
I spilt liquid on my MacBook Air and luckily only busted the keyboard, mainly the power and right arrow key buttons.
I purchased the uppercase from iFixit and it is a good quality part. The install took about 45 minutes, but there was a good hour of troubleshooting afterwards. See my comment on connecting the I/O connector cable above.
After doing any sort of hardware install, especially one as extensive as this, run the Apple Hardware Test application by holding down the D button while booting. It looks at a range of issues that you might miss (like a fan that doesn't spin!) that could cause you problems down the track.
Happy repairs.
Ben - Réponse
This was an awesome and clearly understandable guide, helped by color-coded circles for the various screw sizes! I disassembled, replaced the top and keyboard and reassembled in less than an hour, with my son watching over my shoulder. Well done!
Zac Imboden - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 23
30 derniers jours : 96
Total : 50,867
