Introduction
Utilisez ce tutoriel pour remplacer la carte E/S.
Avant de commencer, éteignez votre appareil. Fermez l'écran et posez-le à l'envers sur une surface douce.
  • Avant de commencer, éteignez votre appareil. Fermez l'écran et posez-le à l'envers sur une surface douce.
  • Retirez les dix vis suivantes :
    • Deux vis Pentalobe P5 9 mm
    • Huit vis Pentalobe P5 2.6 mm
  • Vous trouverez ici le tournevis spécial dont vous aurez besoin pour enlever les vis Pentalobe.
These pentalobe screw sizes can't possibly be right - not even close. Should they perhaps be 0,8 mm and 1,2 mm?
Rulle Boer - Réponse
The screw sizes refer to the length of the shaft, not the diameter of the head or socket. P5 is the standard pentalobe size for all these screws, regardless of length.
I agree that the notation is a little confusing. I think it's because, with standard sized hardware like for your house, you have shaft diameter (say 1/8" or 3mm) and shaft length (say 3" or 7.5cm). So we're programmed to think of small numbers like that as diameter. But in this case, they're length.
budpegasus - Réponse
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Réponse
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Réponse
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Réponse
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Réponse
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Réponse
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Réponse
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Réponse
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Réponse
Mettez vos doigts entre l'écran et le boîtier inférieur et tirez vers le haut pour détacher le boîtier inférieur.
  • Mettez vos doigts entre l'écran et le boîtier inférieur et tirez vers le haut pour détacher le boîtier inférieur.
  • Enlevez la partie inférieure et mettez-la de côté.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
Jeannie Crowley - Réponse
When closing this back up make sure that the antenna cable is tucked away neatly
Gabriel - Réponse
Déconnectez la batterie avant de commencer. Saisissez la languette en plastic transparent attachée au connecteur de la batterie et tirez-la vers le bord avant de l'appareil pour déconnecter la batterie de la carte mère;
  • Déconnectez la batterie avant de commencer.
  • Saisissez la languette en plastic transparent attachée au connecteur de la batterie et tirez-la vers le bord avant de l'appareil pour déconnecter la batterie de la carte mère;
  • Ne tirez pas vers le haut sur le connecteur pendant que vous le déconnectez.
Ajouter un commentaire
Utilisez l'extrémité plate d'un spudger pour tirer le connecteur de la nappe de la carte E/S hors de sa prise sur la carte E/S.
  • Utilisez l'extrémité plate d'un spudger pour tirer le connecteur de la nappe de la carte E/S hors de sa prise sur la carte E/S.
Décollez soigneusement la nappe de la carte E/S de l'adhésif la fixant en haut du ventilateur.
  • Décollez soigneusement la nappe de la carte E/S de l'adhésif la fixant en haut du ventilateur.
La prise du connecteur suivant est particulièrement profonde. Faites attention lorsque vous le débranchez. En tirant doucement sur la nappe de la carte E/S vers le haut, près de sa connexion à la carte mère, utilisez l'extrémité plate d'un spudger pour travailler à tour de rôle sur les côtés du connecteur pour le faire "sortir" de sa prise.
  • La prise du connecteur suivant est particulièrement profonde. Faites attention lorsque vous le débranchez.
  • En tirant doucement sur la nappe de la carte E/S vers le haut, près de sa connexion à la carte mère, utilisez l'extrémité plate d'un spudger pour travailler à tour de rôle sur les côtés du connecteur pour le faire "sortir" de sa prise.
  • Retirez la nappe de la carte E/S.
Utilisez la pointe d'un spudger pour retourner soigneusement le clapet de retenue de la prise ZIF du ventilateur.
  • Utilisez la pointe d'un spudger pour retourner soigneusement le clapet de retenue de la prise ZIF du ventilateur.
  • Assurez-vous de faire levier sur le clapet de retenue à charnière et non sur la prise même.
I did not find it necessary to loosed the retainer flap, unplug the ribbon cable from it's socket, or remove the fan. After removing the fan screws in Step 9, the fan was loose enough that it can be slightly moved to the side. I felt that loosening the retaining flap and removing the fan adds unnecessary potential to damage something. To the contrary, if you bump the fan while it's plugged in, you might damage the ribbon cable.
Michael Kruger - Réponse
Décollez le joint en caoutchouc de l'adhésif sur le dessus du ventilateur.
  • Décollez le joint en caoutchouc de l'adhésif sur le dessus du ventilateur.
Retirez les trois vis suivantes fixant le ventilateur au boîtier :
  • Retirez les trois vis suivantes fixant le ventilateur au boîtier :
    • Une vis Torx T5 de 3,6 mm
    • Une vis Torx T5 de 2,7 mm
    • Une vis Torx T5 de 3,6 mm avec une tête courte
I found it easier to do step 11 before this one.
maccentric - Réponse
Soulevez le ventilateur du côté de la carte E/S et tirez-le du boîtier supérieur. Le retrait du ventilateur déconnecte également la nappe du ventilateur. Veillez à ne pas la déchirer.
  • Soulevez le ventilateur du côté de la carte E/S et tirez-le du boîtier supérieur.
  • Le retrait du ventilateur déconnecte également la nappe du ventilateur. Veillez à ne pas la déchirer.
It is a lot easier to insert the flat ribbon in its socket before placing the fan back in place. BUT DO NOT YET FLIP BACK the retaining flap, until you have seated and screwed the fan. This way in case you pull on the fan by mistake, the flat ribbon is free to come out, otherwise you may tear it.
Rany - Réponse
I did not find it necessary to remove the fan or unplug the ribbon cable from it's socket. After removing the fan screws, the fan was loose enough that it can be slightly moved to the side. I felt that loosening the retaining flap and removing the fan adds unnecessary potential to damage something. To the contrary, if you bump the fan while it's plugged in, you might damage the ribbon cable.
Déconnectez la carte E/S en retirant son câble d'alimentation de sa prise sur la carte mère.
  • Déconnectez la carte E/S en retirant son câble d'alimentation de sa prise sur la carte mère.
  • Tirez le câble parallèlement à la surface de la carte mère vers le bord droit de l'Air.
Utilisez l'extrémité plate d'un spudger pour tirer le connecteur du câble du haut-parleur gauche vers le haut et hors de sa prise sur la carte E/S. Faites levier en dessous des fils.
  • Utilisez l'extrémité plate d'un spudger pour tirer le connecteur du câble du haut-parleur gauche vers le haut et hors de sa prise sur la carte E/S.
  • Faites levier en dessous des fils.
Steps 12 through 16 are not really necessary; you can easily de-route the necessary cables without removing the I/O board. Likewise with reassembly.
Utilisez la pointe d'un spudger pour retourner délicatement le clapet de retenue de la prise ZIF de la nappe du microphone. Assurez-vous de faire levier sur le clapet de retenue et non sur la prise même.
  • Utilisez la pointe d'un spudger pour retourner délicatement le clapet de retenue de la prise ZIF de la nappe du microphone.
  • Assurez-vous de faire levier sur le clapet de retenue et non sur la prise même.
When following these steps in the reverse order to reassemble the machine, I found it much easier to insert the ribbon cable before inserting the I/O board into it's place and installing the screw (Step 14). This adds potential for any sudden movement to damage the ribbon cable, so gentle care must be exercised.
Retirez la seule vis Torx T5 de 3,6 mm fixant la carte E/S au boîtier supérieur.
  • Retirez la seule vis Torx T5 de 3,6 mm fixant la carte E/S au boîtier supérieur.
Retirez délicatement le câble de la caméra de son entaille sur la carte E/S et poussez-la de côté avec la pointe d'un spudger. Retirez délicatement le câble de la caméra de son entaille sur la carte E/S et poussez-la de côté avec la pointe d'un spudger.
  • Retirez délicatement le câble de la caméra de son entaille sur la carte E/S et poussez-la de côté avec la pointe d'un spudger.
Soulevez la carte E/S du côté de la carte mère et retirez-la du boîtier supérieur.
  • Soulevez la carte E/S du côté de la carte mère et retirez-la du boîtier supérieur.
  • Le retrait de la carte E/S déconnecte également la nappe du microphone. Veillez à ne pas la déchirer.
I didn't actually need to remove the IO board, it's enough to remove the screw to let it loose. Therefore also step 12 and 13 are useless.
Emilio - Réponse
THANK YOU. Was able to push the camera cable under the io board without removing it.
samdaman91 -
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
29 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
How can I tell if its my I/O board that is damaged? I cannot hear sound from Aux port or from the speakers on my macbook. Laptop still charges fine though.
Ralphy Sierra - Réponse
Check to see if your USB port on that side works. That was how I know mine was bad.
craig - Réponse
Was easier than I thought to do.
craig - Réponse
If light on magsafe doesn't turn on, is it safe to say the io board needs to be replaced?
Jon Lewin - Réponse
Thumbs up Walter!
jlaramore - Réponse
Worked perfectly for me. In my case the audio device wasn’t able to be found so no sound unless I used a usb or bluetooth speaker. I found that one step here wasn’t necessary was to remove the fan - just swivel it out of the way and so you don’t have to unplug it. Otherwise a very good explanation made it easy for me to fix my 2013 MacAir having no sound.
Josh Marshall - Réponse
Voir les statistiques:
Dernières 24 heures : 6
7 derniers jours : 46
30 derniers jours : 237
Total : 15,560
