Introduction
The logic board bracket holds the trackpad control cable connector and the AirPort/Bluetooth connector securely to the logic board.
Unplug your MacBook Air and power it off before you proceed.
  • Unplug your MacBook Air and power it off before you proceed.
  • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
Ajouter un commentaire
Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs. Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
Disconnect the battery connector by pulling it straight out of its socket.
  • Disconnect the battery connector by pulling it straight out of its socket.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the following nine screws securing the battery to the Air:
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
Lift the battery out of the Air.
  • Lift the battery out of the Air.
Remove the two small Phillips screws securing the logic board bracket to the upper case.
  • Remove the two small Phillips screws securing the logic board bracket to the upper case.
Lift the logic board bracket out of the upper case.
  • Lift the logic board bracket out of the upper case.
4 autre(s) ont terminé cette réparation.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 11
Total : 8,923
