Aller au contenu principal
MacBook Core Duo Bluetooth Board Replacement
Ce dont vous avez besoin
  1. MacBook Core Duo Bluetooth Board Replacement, Battery: étape 1, image 1 de 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core Duo Bluetooth Board Replacement: étape 2, image 1 de 1
    • Lift the battery out of the computer.
  3. MacBook Core Duo Bluetooth Board Replacement, Memory Cover: étape 3, image 1 de 1
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the battery casing, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
  4. MacBook Core Duo Bluetooth Board Replacement: étape 4, image 1 de 1
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
  5. MacBook Core Duo Bluetooth Board Replacement, Upper Case: étape 5, image 1 de 1
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
  6. MacBook Core Duo Bluetooth Board Replacement: étape 6, image 1 de 1
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
  7. MacBook Core Duo Bluetooth Board Replacement: étape 7, image 1 de 1
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
  8. MacBook Core Duo Bluetooth Board Replacement: étape 8, image 1 de 1
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
  9. MacBook Core Duo Bluetooth Board Replacement: étape 9, image 1 de 1
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
  10. MacBook Core Duo Bluetooth Board Replacement: étape 10, image 1 de 1
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
  11. MacBook Core Duo Bluetooth Board Replacement: étape 11, image 1 de 1
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
  12. MacBook Core Duo Bluetooth Board Replacement: étape 12, image 1 de 1
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  13. MacBook Core Duo Bluetooth Board Replacement, Optical Drive: étape 13, image 1 de 1
    • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
  14. MacBook Core Duo Bluetooth Board Replacement: étape 14, image 1 de 1
    • Remove the two Phillips screws from the front edge of the optical drive.
    • The shorter screw (3 mm) is recessed nearest the RAM modules. The other is 3.5 mm.
  15. MacBook Core Duo Bluetooth Board Replacement: étape 15, image 1 de 1
    • Disconnect the orange optical drive ribbon cable from the logic board.
  16. MacBook Core Duo Bluetooth Board Replacement: étape 16, image 1 de 1
    • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
  17. MacBook Core Duo Bluetooth Board Replacement: étape 17, image 1 de 1
    • Disconnect the (once again) newly-revealed hard drive cable.
  18. MacBook Core Duo Bluetooth Board Replacement: étape 18, image 1 de 1
    • Peel up the foil tape between the fan and the optical drive.
    • Remove the 8.5 mm Phillips screw securing the display data cable to the metal framework.
  19. MacBook Core Duo Bluetooth Board Replacement: étape 19, image 1 de 1
    • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
  20. MacBook Core Duo Bluetooth Board Replacement: étape 20, image 1 de 1
    • Remove the 2.8 mm Phillips screw securing the optical drive.
    • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
    • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
    • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
  21. MacBook Core Duo Bluetooth Board Replacement: étape 21, image 1 de 1
    • Lift the Bluetooth antenna board from the right side of the optical drive.
    • Deroute the hard drive cable from along the front of the optical drive.
  22. MacBook Core Duo Bluetooth Board Replacement: étape 23, image 1 de 1
    • Lift the front edge of the optical drive and slide it up and out of the computer.
  23. MacBook Core Duo Bluetooth Board Replacement, Bluetooth Board: étape 24, image 1 de 1
    • Use a spudger to disconnect the gold Bluetooth antenna connector from the Bluetooth board.
  24. MacBook Core Duo Bluetooth Board Replacement: étape 25, image 1 de 1
    • Pry the Bluetooth board up from the lower case.
  25. MacBook Core Duo Bluetooth Board Replacement: étape 26, image 1 de 1
    • Peel back the orange tape covering the Bluetooth board so you can access the data cable connector.
    • Disconnect the data cable from the Bluetooth board.
    • Lift the Bluetooth board out of the computer.
12 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
Un commentaire
Perfect instructions, thank you so much! Now my good-ole macbook will stay asleep again! Yay!!!!
Alan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 13
Total : 25,816
