Introduction
This detects the light level in the room to adjust the backlit keyboard.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Ajouter un commentaire
Remove the three identical Phillips screws from the memory door.
  • Remove the three identical Phillips screws from the memory door.
Tip for new players - print this guide, then use Sello tape to tape the screws from each step on the picture. Keeps them all organised and easy to know which screws belong to which step when putting it all back together
MPB Monkey - Réponse
Thanks a lot for this great advice. I followed it, and it turned out to be very useful and practical.
Ralf Bergs -
Quote from MPB Monkey:
"...Tip for new players - print this guide, then use Sello tape..."
It's one word: Sellotape, the biggest brand in Europe. :-)
matthk - Réponse
In regard to the incredible amount of TINY screws, get an Ice Cube Tray or something with AT LEAST 8 compartments, then, when taking out the screws, mark EACH compartment with the step # and how many screws that were taken out, and used for THAT STEP (such as Step # 3 = 4 of 4 screws. Label EACH compartment, and keep them in line of each step. When it comes time to put everything back together, just reverse your Ice Cube Tray, and follow the Steps in Reverse!
As far as marking each compartment, try these POST IT PENS!!!
http://www.staples.com/Post-it-Flag-Ball...
GOOD LUCK! Take your time, it's not as difficult as it seems!
JerseyJeepGurl
JerseyJeepGurl - Réponse
An ice cube tray is definitely the way to go!
Martok Bulls -
This guide helped me to remove the keyboard on my MBP, but it doesn't take you further to take the keyboard apart. If you REALLY want to look inside the keyboard, you'll need to remove additional phillips screws (10), and carefully remove the inner plastic/clear layers inside the keyboard.
I did this to look for physical damage inside the keyboard and noticed that the black plastic? sheet was torn on my letter 'v', which was one of the keys not working. I did not see any physical sign anywhere else on the keyboard, though.
So, after pulling the defective keyboard away and installing the new one purchased from iFixit, putting everything back together is not too difficult, just reverse.
One thing, though: Check and double-check before you tighten the case screws to make sure your keyboard backlight is working. I noticed I had forgotten to plug it in, luckily for me before I put all the screws on the case.
To avoid losing any screws, print this guide and use clear tape to tape the screws next to the step. Use double-tape to avoid tearing or one of the tiny screws from falling out.
Good luck!
Thanks iFixit for helping me replace my MBP's keyboard!
juanortuno - Réponse
Thank you for some excellent advice form JerseyJeep Gurl
Quote from SubodhJ:
SubodhJ - Réponse
Worked perfect on my 4,1 mbp. Took ~15 min.
I don't see a boost in speed... or is just me?
I used 500 GB 7200 RPM Seagate SATA Hard Drive model ST9500420AS.
(if has a G letter at the end (ASG) is the one with built in shock protection who conflict sometimes with the mac own G protection).
crus - Réponse
This guide was awesome. I used JerseyJeepGurl's suggestion and used an egg carton, numbering each cavity as a step in the guide. So for a step that had me remove 3 different kinds of screws, I had a cavity for each, numbered: 1a, 1b, 1c and wrote a,b,c on the guide itself next to each bullet point in the step. It was awesome.
I guess that before starting I overlooked what a T6 torx actually was. I started this process at 8pm and realized right away that I did not have a set that small and of course all stores were closing. Lowes actually had an awesome fine torx driver set for only 7 bucks!
So that you fixit.
tech4eleven - Réponse
Quote from tech4eleven:
So that you fixit.
Thank you everybody for "thanking me" on the compartment advice! Also, just about ANY Auto parts store will have a set of Torx Screw drivers, in a handy little set, that is all together. Good luck everybody,,remember,TAKE YOUR TIME, BREATH, AND DON'T GET FRUSTRATED!!! (STEALING ADVICE FROM PEARL JAM,,BREATH,JUST BREATH),,,,AND YOU'LL BE ABLE TO DO IT YOURSELF!
JJG
Quote from JerseyJeepGurl:
JerseyJeepGurl
Michael Fredrickson - Réponse
Quote from Michael Fredrickson:
I get a piece of "corrugated" cardboard and draw an outline of the laptop and all the "compartments" that are accessed. When you take a screw out simply punch it threw top layer of the cardboard exactly where it goes. Multiple compartments - just draw another diagram on the cardboard. Voila!
I just finished replacing my hard drive following these instructions and they were perfect. The only minor complication involved the ribbon cable connecting to the sleep light and IR sensor connectors. The entire cable was tightly glued to the hard drive. But I got it loose with 10 minutes of gentle prying with a spudger.
To keep track of the screws I just sketched an outline of the bottom panel, taped the screws in the right places and numbered them with the step numbers.
Tom McAuliffe - Réponse
I just used that Glad Press' N Seal. I just cut a 4 in piece, cut slits in it to about half way, Put the screws on there, and fold the pieces over the screws. You can number them, i just kept track of them. Also, you might not need that much, i just cut that much just to be safe.
benchallinor27 - Réponse
I use magnet
I use the magnet that close the refigerator door.
The screws are put on the magnet, so it didnot fall from the table.
i am french so sorry for my english
Madoc -
Just another idea for a container for all the little screws: pillbox. I got one for about $1.00 at the store with 14 compartments.
Brian Littmann - Réponse
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Remove the following 6 screws:
  • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Remove the four 3.2 mm Phillips screws on the port side of the computer.
  • Remove the four 3.2 mm Phillips screws on the port side of the computer.
"port side of the computer" should read "starboard side". It's on the right-hand side when the computer is positioned normally in front of you.
joeycoole - Réponse
Port side as in I/O port side, as in the side that has the FireWire and ethernet ports. This is a MacBook, not a sailboat ;)
Andrew Bookholt -
Maybe I'm too used to running flight simulators on my Macs. But to us sailors or pilots, it would perhaps be clearer if the instructions mentioned "I/O port side" as Andrew did above.
Honestly, it never crossed my mind that 'port' refered to in/out…
joeycoole -
Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
In my machine the screw closest to the power connector had a slightly thicker head, and would not sit flush, upon reassembly, unless it was returned to the same hole.
Martin Kenny - Réponse
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
Be super careful not to bend the metal tabs that hook the upper case into the lower case. If bent these make it challenging to close and reattach the upper case.
lama - Réponse
I had already done this once and now have a larger SSD to put in and cannot get past this step as the back just will not pop off. In fact- the front comes off fine but the back, where you cannot get the spudger, is "glued" or wedged solid. I suspect that the rear screw tabs have jammed. :(
Stefanie - Réponse
I would not rock the case up and back. There are 4 plastic connectors that need to come loose, start on the left side with a spudger about a quarter of the distance from the edge and pop them up from left to right, one by one.
maccentric - Réponse
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Remove the upper case.
Kudos for this fantastic walk-through of replacing the hard drive. I just swapped in a new SSD and it was a piece of cake!
On Step 10, I tried just propping up the keyboard and leaving it connected to the logic board. It worked for a while but eventually the ribbon popped off. Luckily it wasn't damaged and it's super easy to replace.
DJR - Réponse
Same happened to me. No damage here either. :-)
Ralf Bergs -
Disconnect the left ambient light sensor cable from the logic board by placing a spudger beneath the cable and lifting up.
  • Disconnect the left ambient light sensor cable from the logic board by placing a spudger beneath the cable and lifting up.
Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
  • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
Remove the single silver Phillips screw securing the clear plastic shield over the left ambient light sensor.
  • Remove the single silver Phillips screw securing the clear plastic shield over the left ambient light sensor.
  • Lift the clear plastic shield off the left ambient light sensor.
Use a spudger to pry the left ambient light sensor board out of its housing on the left speaker.
  • Use a spudger to pry the left ambient light sensor board out of its housing on the left speaker.
  • Lift the left ambient light sensor board out of the computer.
iRobot
Membre depuis le 24/09/2009
1 Réputation
745 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 7,787
