Introduction
Mettez à niveau votre RAM et optimisez instantanément la vitesse.
Ce dont vous avez besoin
Retirez les dix vis suivantes par lesquelles le boîtier inférieur est fixé au boîtier supérieur :
Sept vis Phillips 3 mm.
Trois vis Phillips 13,5 mm.
Écartez les deux clips de chaque côté du module de RAM simultanément pour libérer ce dernier.
Saisissez le module de RAM par les côtés et sortez-le de son emplacement en le levant bien droit.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
159 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
5 commentaires
I bought and installed 4GB x2 RAM for my Mid 2009 15 inch MacBook Pro and it was easy and is working great. Before this I had 4GB and it was being maxed out. It was very easy. I did purchase the required tools which made it simple. I also swapped the battery at the same time. I am writing this from the same computer and it is working well. Good luck!
I had no trouble installing the 4 GB RAM I bought for my Mid 2009 15 Inch MacBook Pro. The mistake I made though was not realising that my machine has two RAM slots. I only bought one chip! So now I have to buy another one.
If you read this before you buy some RAM, make sure you check how many slots your computer has!
Also, I must say the customer support from ifixit is great. I messaged them about this and some other issues I was having and I got a detailed response from them within a couple of days. Thanks guys!
I replaced my original 2x 2gb ram with 2x 4gb RAM following your instructions. However, upon boot up, it’s only showing 1 of the 2 4gb chips. Any tips on how to get both seated correctly?
Never mind. I was able to pop the second chip back out and get it seated properly.
