Introduction
Charges battery and connects battery to logic board.
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
  • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Before upgrading to a larger HD, you'll want to "clone" your original HD using the donation-ware program "Carbon Copy Cloner" (http://www.bombich.com/). Put the new HD in an external case; clone the original; test the clone (by starting up with it), then take apart the MacBook to put the new HD in the MacBook, and the original in the external case for use as a backup, etc. (You can't just drag the contents of the original HD to the new HD, and expect it to work; not since the days of OS 9 and before.)
amiller770 - Réponse
Can I put more than two gigabytes of RAM in?
Noah Nsangou - Réponse
mine has 2g*2=4 gb ram in. you should be fine
on mac forum it suggested to put 4gb and a 2gb in a1261.
david -
I made the mistake of wanting to do a clean install of OS and start fresh after installing a SSD. Now I can't install most browsers on OSX Leopard. Does anyone know what is the most current version of OS I can put on this system? (disk or download) Can I get to Snow or Lion?
2006 17" MackBook Pro Model#A1151
2.16 GHz Intel Core Duo
Memory: Two 1GB 667 MHz
Hard Drive: Corsair Force GS: SSD 128GB
scannon - Réponse
You can install OS X 10.7 LION and no later version. Although LION runs ok with 2GB RAM it does help to get 1GB + 2GB = 3GB. Even if you install 2 X 4GB you will only utilize 3GB. Installing a SSD seems to make no difference since the SATA bus is only 1.5GB/s. A good 5400rpm disk is good enough. I even run BootCamp and Windows 7. Works fine. Not fast but fine. My A1212 refuses to die :-)
asle -
There seems to be some discrepancy about whether or not installing a SSD will help. See Phil's earlier comment from October 2015: there, *he* claims that having an SSD increases the load times significantly, (even though -- of course -- 1.5Gbps is not ideal)...
His quotation, (re-)cited integrally:
Just replaced my old HD with a Corsair Force LX SSD (which is SATA 1-3 compatible as required by this model) with success now my old 'outdated' laptop has super fast loading times and is postively flying faster than the speed of 'sound'. Thanks for the guide. Only problem I faced was replacing the top panel which after a few minutes of panic realised the rubber mounted Mic next to the left speaker had risen up when I had removed the top panel so after carefully pushing it back into place the panel fitted back how it should, so beware of this possible problem.
Phil - 10/07/2015
at0gjm -
Remove the four identical Phillips 3.4 mm screws from the memory door.  These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Ajouter un commentaire
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove.  On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
One of the screws here wouldn't bite going back in. I'm 100% certain it's the same screw that came out of it but it wouldn't bite going back, neither would any of the other two in this section in that particular hole.
Damon B - Réponse
To Damon - possibly the thread on the bottom of the upper case is obstructed.
I found that I needed to fight the latch magnet with the right-most screw in the photo. The screw was pulled away from the hole so a magnetized screwdriver was not enough to place it. I needed tweezers to hold the screw in place until it bit.
Yishai Sered - Réponse
Remove the following six screws:
  • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
Note for re-assembly: For the hinge use the longest four Phillips screws.
R L - Réponse
The Philips screws in Step 5 are longer than the other Philips screws. Would be better if the instructions differentiated them. Otherwise it is possible to use the wrong screws in Step 7 when reassembling.
Alex - Réponse
These instructions are actually wrong. The 14.5 mm screws are for along the hinge, the 2 on either side of the RAM slot are about 10 mm.
Andrew Patterson - Réponse
Remove the four 3.4 mm Phillips screws on the port side of the computer.
  • Remove the four 3.4 mm Phillips screws on the port side of the computer.
When reassembling, please be careful not to screw into the wrong spot. I accidentally screwed into the DVI port and it was hard to remove the screw after that. I had to disassemble the whole thing again, only to find that I couldn't remove the screw from within as it was encased. After much scraping and prodding with a sewing needle, I was able to get that screw out. Phew!
isotope434 - Réponse
Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
Screw on the right is shorter
mikefal - Réponse
The screws on mine were exactly the same size.
Citation de mikefal :
Chris - Réponse
What are these two screws called?
ian - Réponse
Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
WOW this step is very hard!!! its a serious suction cup..
nya - Réponse
Once the upper case is free...Carefully tilt the upper case from the front towards the screen as their is a ribbon cable directly beneath the keyboard and trackpad that will need to be removed in the next step.
Troy - Réponse
Be very careful not to bend the screw tabs on the top case the perimeter screws attach to. Bending them causes them to quickly fatigue and potentially break off. When reassembling the top case, be sure the tabs are all *inside* the case before reseating it. If you get resistance, pull the case back up, check the tabs and reseat the top case again.
Sheldon Carpenter - Réponse
Disconnect the trackpad and keyboard ribbon cable from the logic board.
  • Disconnect the trackpad and keyboard ribbon cable from the logic board.
  • Remove the upper case.
Disconnecting this cable is optional, if instead you tip up the top case ~75 degrees, propping it up with something non-metalic (wedged in or by the battery compartment). Unplugging a connector from the main circuit board always carries slight additional risk.
It's not really necessary to disconnect the trackboard/keyboard ribbon cable. You can simply lean the upper case against the LCD.
Russ Greene - Réponse
how reconnect this cable?
anatole - Réponse
I did this with and without step 10 (removing the upper case with detached cable). Removing the cable is risk, putting it back on was not so easy. But then, leaning the keyboard part against the LCD while replacing the hard drive is also risky.
tobybaier - Réponse
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Remove the following three screws:
  • Remove the following three screws:
    • Two black 4 mm T6 Torx screws on either side of the SuperDrive.
    • One 8.7 mm silver (black in some models) T6 Torx screw at the back of the drive near the speaker.
Use one hand to pull back the speaker cable and use your other hand to lift the optical drive up and out of the computer.
  • Use one hand to pull back the speaker cable and use your other hand to lift the optical drive up and out of the computer.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Disconnect the ten indicated connectors from the logic board. The connectors have different positions for the four MacBook Pro revisions covered by this guide, and their locations are highlighted in the three pictures on this step. The connectors have different positions for the four MacBook Pro revisions covered by this guide, and their locations are highlighted in the three pictures on this step.
  • Disconnect the ten indicated connectors from the logic board.
  • The connectors have different positions for the four MacBook Pro revisions covered by this guide, and their locations are highlighted in the three pictures on this step.
this being one step seems daunting to a first-timer... also, my board looks a little different (macbook pro 17" core 2 duo)
zeroasterisk1 - Réponse
Also - no thermal sensor (step 15) on my macbook pro 17" core 2 duo
The logic board screws can strip very easily. I had 3 do so using a brand new T6 hand screwdriver.
I was able to get them out eventually by pushing a T7 very hard into the grooves and essentially rocking the screw. What I mean is, just trying to get it to make that crack sound that the screw came loose. Pushing hard down and trying to twist just a little, and repeat. Eventually they all cracked loose and came out.
Good luck and be careful. My MBP is able to play Hulu videos now without overheating and stuttering!
Joe Mattiello - Réponse
How to disconnect the connectors? Slide the metal one on the upper left corner out (to the left) with your fingernails or spudger. Pop the black plastic ones out by gently wedging the spudge under from the wire side. Slide the other plastic connectors out with fingernails on each corner in the direction of the wires.
rgwc - Réponse
Citation de zeroasterisk1 :
Also - no thermal sensor (step 15) on my MacBook Pro 17" core 2 duo
Same with mine - no sensor.
rgwc - Réponse
A1261 also does not have the thermal sensor cable. Also, did anyone else notice the unused socket to the right of the RAM?
sudowork - Réponse
Rotate the large display data cable to the left and disconnect the small right thermal sensor cable beneath.
  • Rotate the large display data cable to the left and disconnect the small right thermal sensor cable beneath.
  • If you have the A1261 model, the right thermal sensor cable is located in between the right fan connector and display data cable.
My Model A1212 did not have a thermal sensor cable connected.
James Rybolt - Réponse
Remove the single black 4 mm T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
  • Remove the single black 4 mm T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
  • Lift the clear plastic shield off the right ambient light sensor.
Peel up the orange Kapton tape securing the left thermal sensor cable to the logic board.
  • Peel up the orange Kapton tape securing the left thermal sensor cable to the logic board.
  • If you have a MacBook Pro 17" Model A1229, this is the middle thermal sensor.
Remove the following twelve screws:
  • Remove the following twelve screws:
    • Seven 6.5 mm T6 Torx screws.
    • Two shanked 7.6 mm T6 Torx screws securing the battery connector to the lower case.
    • Three 7.8 mm T6 Torx screws.
Lift up the left side of the logic board and disconnect the multi-colored power connector from the bottom of the board.
  • Lift up the left side of the logic board and disconnect the multi-colored power connector from the bottom of the board.
Re-assembling the motherboard was quite complicated, because several pieces must fit before it is in position. I did it by putting the right speaker first, then the right side of the motherboard, making sure none of the cables got caught and then with some difficulty connected the board with this cable.
Javier Lillo - Réponse
Grasp the logic board at the left side and at the thin section near the right fan, and rotate the logic board out of the lower case.
  • Grasp the logic board at the left side and at the thin section near the right fan, and rotate the logic board out of the lower case.
If the right speaker assembly remains attached to the logic board, hold the logic board with one hand and slide the speaker up slightly to free it from the logic board.
  • If the right speaker assembly remains attached to the logic board, hold the logic board with one hand and slide the speaker up slightly to free it from the logic board.
  • To properly reassemble your MacBook Pro, you'll have to clean off and replace the thermal compound from the three chips on the underside of the logic board. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
Disconnect the multi-colored battery connector from the logic board.
  • Disconnect the multi-colored battery connector from the logic board.
  • To properly reassemble your MacBook Pro, you'll have to clean off and replace the thermal compound from the three chips shown here. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
4 autre(s) ont terminé cette réparation.
iRobot
Membre depuis le 24/09/2009
1 Réputation
750 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 33
Total : 12,104
