Aller au contenu principal
MacBook Pro 17" Unibody Rear Display Bezel Replacement
Ce dont vous avez besoin
  1. MacBook Pro 17" Unibody Rear Display Bezel Replacement, Lower Case: étape 1, image 1 de 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 2, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 2, image 2 de 2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Rear Display Bezel Replacement, Battery: étape 3, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement, Battery: étape 3, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement, Battery: étape 3, image 3 de 3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Rear Display Bezel Replacement, Display: étape 4, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement, Display: étape 4, image 2 de 2
    • Before disconnecting the camera cable, a small plastic retainer stuck to the logic board must first be moved out of the way. In late-2011 models you can skip this step because there is not a plastic retainer on the camera cable connector.
    • Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
  5. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 5, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 5, image 2 de 2
    • Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
    • The camera cable socket is very fragile. Do not apply any upward force to this socket, as it may break off the logic board. Pull the camera cable parallel to the face of the logic board.
  6. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 6, image 1 de 1
    • Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
    • Pull the cable parallel to the face of the optical drive.
  7. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 7, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 7, image 2 de 2
    • Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing. For late-2011 models check out the other picture because the connector location is in a totally different location.
  8. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 8, image 1 de 1
    • Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
  9. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 9, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 9, image 2 de 2
    • If present, remove the small piece of EMI foam near the Bluetooth board.
    • De-route the camera cable from the slot molded into the Bluetooth board housing.
  10. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 10, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 10, image 2 de 2
    • Remove the two 7.1 mm Phillips screws securing the camera cable retainer to the upper case.
    • Remove the camera cable retainer from the upper case.
  11. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 11, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 11, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 11, image 3 de 3
    • Lift the black plastic flap attached to the display data cable retainer and rotate it toward the DC-In side of the MacBook.
    • Pull the display data cable out of its socket.
    • The display data cable socket is very fragile. Do not lift the connector upward as you disconnect it, as the socket may break off the logic board. Pull the cable parallel to the face of the logic board.
  12. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 12, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 12, image 2 de 2
    • Remove the two 7.1 mm Phillips screws securing the display data cable retainer to the upper case.
    • Remove the display data cable retainer.
  13. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 13, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 13, image 2 de 2
    • Remove the two outer 6.8 mm T6 Torx screws from each of the two display brackets (four screws total).
    • We purposely have you leave one screw attaching each display bracket to the upper case to aid in future steps.
  14. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 14, image 1 de 1
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the lower display bracket.
  15. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 15, image 1 de 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T6 Torx screw securing the display to the upper case.
  16. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 16, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 16, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 16, image 3 de 3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
    • During reassembly, fit the display into place and install the display bracket Torx screws, then close the lid and lay the laptop upside-down to check the alignment of the screen to the body. If necessary, loosen the screws and realign the display before tightening.
  17. MacBook Pro 17" Unibody Rear Display Bezel Replacement, Front Display Glass: étape 17, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement, Front Display Glass: étape 17, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement, Front Display Glass: étape 17, image 3 de 3
    • It's very easy for the rubber display gasket to deform when exposed to heat, so it is best to remove it before using a heat gun to remove the display glass.
    • Insert a plastic opening tool underneath the black rubber gasket at the bottom left corner of the display assembly.
    • Gently pry the wide edge of the gasket up from the back case.
  18. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 18, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 18, image 2 de 2
    • Starting with the freed corner, pull the left gasket off the left side of the display assembly.
  19. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 19, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 19, image 2 de 2
    • Continue pulling the display gasket off the display assembly across the top edge.
  20. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 20, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 20, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 20, image 3 de 3
    • Continue pulling the display gasket off the display assembly down the right side.
    • Pull the gasket off the bottom edge of the display to completely free it and set it aside.
  21. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 21, image 1 de 1
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display.
    • Before starting, be sure to clean the display glass with a lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier.
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
  22. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 22, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 22, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 22, image 3 de 3
    Outil utilisé dans cette étape :
    Heavy-Duty Suction Cups (Pair)
    $14.95
    J'achète
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the lower right corner of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Gently lift the corner of the display glass enough to insert a guitar pick between it and the display assembly.
    • Use the guitar pick to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel along the right edge of the display up to the halfway point.
    • Leave the guitar pick in place halfway up the right side of the display and remove the suction cup.
  23. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 23, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 23, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 23, image 3 de 3
    • Use a heat gun to soften the adhesive under the display glass along the right and top edges of the display.
    • Attach a suction cup to the upper right corner of the front glass panel.
    • Pull up on the glass panel while you use a second guitar pick to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
  24. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 24, image 1 de 1
    • Work along the top edge of the display assembly, carefully prying the adhesive up with the guitar pick.
    • Stop prying about an inch before you reach the iSight camera. Leave the guitar pick in place and remove the suction cup.
  25. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 25, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 25, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 25, image 3 de 3
    • Repeat steps 22 through 24 for the left side and the left top edge of the display.
  26. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 26, image 1 de 1
    • After prying up the three edges of the display glass, you should have four guitar picks resting underneath the panel, as shown.
  27. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 27, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 27, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 27, image 3 de 3
    • With the heat gun set to low, heat the bottom edge of the display to soften the adhesive holding the glass in place.
    • A number of cables and the AirPort card lie underneath the clutch cover, so do not heat the area for too long.
    • Slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use a plastic opening tool to free any part of the lower edge of the glass that is still attached.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
  28. MacBook Pro 17" Unibody Rear Display Bezel Replacement, LCD: étape 28, image 1 de 1
    • Remove the four 2.3 mm Phillips #00 screws securing the LCD to the rear display bezel.
  29. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 29, image 1 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 29, image 2 de 3 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 29, image 3 de 3
    • Lift one of the top corners of the LCD panel out of the rear bezel with a plastic opening tool.
    • Grasp the top corners of the LCD and rotate it upwards, slightly out of the display.
    • Pull the LCD toward the top of the display panel, freeing the screw tabs from underneath the rear display bezel.
  30. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 30, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 30, image 2 de 2
    • Carefully guide the LCD cable through the slot in the rear display bezel.
    • You may need to rotate the display slightly to get the cable through.
  31. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 31, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 31, image 2 de 2
    • Flip the LCD over and lay it face down, being careful to not put too much stress on the display cable.
    • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
  32. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 32, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 32, image 2 de 2
    • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
    • Pull the display data cable straight away from its socket on the LCD.
    • Lift the LCD out of the display assembly and set it aside.
  33. MacBook Pro 17" Unibody Rear Display Bezel Replacement, Camera Board: étape 33, image 1 de 1
    • Pull the camera/AirPort cable straight out of its socket on the camera board.
  34. MacBook Pro 17" Unibody Rear Display Bezel Replacement, Camera/AirPort Cable: étape 34, image 1 de 1
    • Remove the 2.7 mm Phillips #00 screw securing the AirPort board bracket to the rear display bezel.
  35. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 35, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 35, image 2 de 2
    • Move the AirPort board bracket towards the bottom of the display case with the tip of a spudger so that it does not block the AirPort board cable.
    • Use the tip of a spudger to disconnect the AirPort board cable by rocking it back and forth until it is free.
  36. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 36, image 1 de 1
    • Once the cable is disconnected, remove the plastic bracket from the rear display bezel.
  37. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 37, image 1 de 1
    • Remove the single 1.9 mm Phillips #00 camera cable screw.
  38. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 38, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 38, image 2 de 2
    • De-route the camera/AirPort cable from the display housing.
    • Carefully pull the camera/AirPort cable through the slot in the aluminum housing underneath the right display hinge.
  39. MacBook Pro 17" Unibody Rear Display Bezel Replacement, Rear Display Bezel: étape 39, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement, Rear Display Bezel: étape 39, image 2 de 2
    • Carefully pull the display cable through its slot in the aluminum housing, rotating it as necessary to fit through the opening.
  40. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 40, image 1 de 1
    • Use the tip of a spudger to disconnect the two antenna cable connectors from the AirPort board.
  41. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 41, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 41, image 2 de 2
    • Remove the four 4.0 mm Phillips #00 screws securing the AirPort antenna to the rear display bezel.
  42. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 42, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 42, image 2 de 2
    • Remove the two 3.1 mm Phillips #00 screws securing the AirPort board to the rear display bezel.
    • Lift and remove the AirPort board from the rear display bezel.
  43. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 43, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 43, image 2 de 2
    • Remove the three 5.2 mm T6 Torx screws securing the right clutch hinge to the rear display bezel.
  44. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 44, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 44, image 2 de 2
    • Lift and remove the right clutch hinge from the rear display bezel.
    • Remove the plastic hinge guard as well, making sure to not lose it.
  45. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 45, image 1 de 2 MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 45, image 2 de 2
    • Remove the three 5.2 mm T6 Torx screws securing the left clutch hinge to the rear display bezel.
  46. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 46, image 1 de 1
    • Lift and remove the left clutch hinge from the rear display bezel.
  47. MacBook Pro 17" Unibody Rear Display Bezel Replacement: étape 47, image 1 de 1
    • The rear display bezel remains.
Brett Hartt
Membre depuis le 04/12/10
127 897 Réputation
143 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
2 commentaires
I own the early 2011 anti-glare version (MC725LL/A) and the display assembly is completely different. As it is the anti-glare version there is no glass panel. There is no "wide edge of the gasket" (Re: Step 18) on the anti-glare version, so I am unsure at which point should I insert my opening tool and to begin prying at. After that, I also need instructions on how to remove the aluminum front bezel. Can someone please update the related steps for the anti-glare version?
Jacky Fong - Réponse
Here is instructions for anti-glare version (MC725LL/A): https://youtu.be/HLwO1YV5M8M
timothy.step -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 16
Total : 6,482
