Aller au contenu principal
Macintosh IIsi Hard Drive Replacement
Ce dont vous avez besoin
  1. Macintosh IIsi Hard Drive Replacement, Top Case: étape 1, image 1 de 2 Macintosh IIsi Hard Drive Replacement, Top Case: étape 1, image 2 de 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Hard Drive Replacement: étape 2, image 1 de 3 Macintosh IIsi Hard Drive Replacement: étape 2, image 2 de 3 Macintosh IIsi Hard Drive Replacement: étape 2, image 3 de 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Hard Drive Replacement, Hard Drive: étape 3, image 1 de 3 Macintosh IIsi Hard Drive Replacement, Hard Drive: étape 3, image 2 de 3 Macintosh IIsi Hard Drive Replacement, Hard Drive: étape 3, image 3 de 3
    • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
    • Start by pushing these two tabs out, and lifting the drive up.
    • Then, flip the drive over, and remove the connection cables.
  4. Macintosh IIsi Hard Drive Replacement: étape 4, image 1 de 3 Macintosh IIsi Hard Drive Replacement: étape 4, image 2 de 3 Macintosh IIsi Hard Drive Replacement: étape 4, image 3 de 3
    • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
    • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
    • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
4 autres ont terminé cette réparation.
Chris Green
Membre depuis le 10/11/09
36 978 Réputation
49 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 528 tutoriels rédigés
2 commentaires
Hello cano you please tell me how is the jumpering setting for a Quantum Prodrive LT 700MB
Juan - Réponse
Is there a way to read the HDD on a PC?
Charles - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 3,950
