Introduction
The Macintosh IIsi uses 4 30-Pin RAM SIMMs, installed in pairs of two for a maximum capacity of 65MB (4X16MB + 1MB). It has 1MB of RAM soldered to the logic board.
Pièces
Aucune pièce nécessaire.
Start by turning the computer around, and remove this #0 Phillips Screw. There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  • Start by turning the computer around, and remove this #0 Phillips Screw.
  • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
Ajouter un commentaire
Now lift these two clips, and slowly pivot the case up. You can now seperate the top of the computer from the rest of the machine. You can now seperate the top of the computer from the rest of the machine.
  • Now lift these two clips, and slowly pivot the case up.
  • You can now seperate the top of the computer from the rest of the machine.
The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB.  It has 1MB soldered to the logic board as well. Start with this SIMM.  Push these 2 metal tabs outward, then push the ram forward.  It can then be lifted out.  You have to remove the SIMMs in order, starting with the one you just removed.  You can then work your way through all of them. Start with this SIMM.  Push these 2 metal tabs outward, then push the ram forward.  It can then be lifted out.  You have to remove the SIMMs in order, starting with the one you just removed.  You can then work your way through all of them.
  • The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB. It has 1MB soldered to the logic board as well.
  • Start with this SIMM. Push these 2 metal tabs outward, then push the ram forward. It can then be lifted out. You have to remove the SIMMs in order, starting with the one you just removed. You can then work your way through all of them.
1st Photo: The RAM Module 1st Photo: The RAM Module 1st Photo: The RAM Module
  • 1st Photo: The RAM Module
3 autre(s) ont terminé cette réparation.
Chris Green
Membre depuis le 11/10/2009
31 975 Réputation
47 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
277 membres
724 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 1,877
