Aller au contenu principal
Macintosh PowerBook 1400 Series Hard Drive Replacement
Ce dont vous avez besoin
  1. Macintosh PowerBook 1400 Series Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 2, image 1 de 1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 3, image 1 de 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Hard Drive Replacement, CD-ROM Drive: étape 4, image 1 de 1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 5, image 1 de 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 6, image 1 de 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Hard Drive Replacement, Keyboard: étape 7, image 1 de 1
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 8, image 1 de 1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 9, image 1 de 1
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 10, image 1 de 1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 11, image 1 de 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 12, image 1 de 1
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 13, image 1 de 1
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 14, image 1 de 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 15, image 1 de 1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 16, image 1 de 1
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 17, image 1 de 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 18, image 1 de 1
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 19, image 1 de 1
    • Remove the keyboard.
  20. Macintosh PowerBook 1400 Series Hard Drive Replacement, Hard Drive: étape 20, image 1 de 1
    • Locate and identify the two screws that attach the hard drive to the computer.
  21. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 21, image 1 de 1
    • Remove the screws with a Phillips #0 screwdriver.
  22. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 22, image 1 de 1
    • Once the screws are removed, lift up the end of the hard drive using your finger tips.
  23. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 23, image 1 de 1
    • Fully lift the hard drive vertically against the side of the computer.
  24. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 24, image 1 de 1
    • Push a finger down onto the plastic strap.
  25. Macintosh PowerBook 1400 Series Hard Drive Replacement: étape 25, image 1 de 1
    • Remove the hard drive from the computer by pushing down on the plastic strap and pulling up on the hard drive.
11 autres ont terminé cette réparation.
Jeffrey Huntley
Membre depuis le 04/01/11
248 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-39, Forte Spring 2011 Membre de l'équipe Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 membres
6 tutoriels rédigés
Un commentaire
Hi iFixIt thanks for all the details BUT the keyboard can indeed stay in
when changing the hard drive. Just slide it a bit to the right after step
11, the ribbon cble does not take any damage. SO: from step 12 jump
straight to step 20. The heat sink can stay untouched, which i find not
unimportant to mention. Regards, TB75
TB75 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 40
Total : 8,717
